Russian Article about Fet tube emulation.
- briggs
I've been looking at this: http://www.sugardas.lt/~igoramps/article68/article.htm
My russian, however, is crap. So I don't understand what the hell is going on! Can anyone explain what exactly the article is on about? Would it be possible to adapt one of these stages into a 9v tube type booster?
- bajaman
- Has thanked: 566 times
- Been thanked: 2014 times
ah - those crazy Russians
- analogguru
Hmmmm.....
And why don´t you read the cited patents (links at the bottom) from which this article has been derived ?
yes .....really.... they are in english...
- briggs
- briggs
- analogguru
.djvu is a (special) fileformat like .pdf (or .jpg).
Hmmm....when you have some time, maybe you can look for an account at freepatentsonline or a similar possibilty for free download of patents ?
In the meantime you can try this:
US Pat. 5647004
US Pat. 5619578
US Pat. 5647004
US Pat. 5619578
- briggs
- briggs
- estragon
Drain is biased to 2/3 of the supply voltage, which means 6V for a 9V supply.
Regarding the calculation of the resistors, go to the original article (linked in the first post) and scroll down to Figure 7, then, just below there is a link to an MS Excel spreadsheet that does all the calculations for you.
From top to bottom enter 9 V for the supply voltage, 22 kohm for the drain resistor, 0.8 V for the JFET's pinch-off voltage, and 0,6 mA for Idss (this data is for an average J201), then you get the following for the source resistors:
r = 0,68 kohm (680 ohms)
R = 2,39 kohm (use 2k4 or closest available value)
If I understand correctly, the diode should be a germanium type. You may use 1N34A or 1N60.
Good luck.
Good luck.
- briggs
Thanks a bomb Estra, I've been fiddling with that Excel thing for about an hour now trying to work out what all those symbols were... I'm just moving into learning all about Fet and the like, I've done opamps - fully versed in their operation. I've been reading this too - a good resource for Fet N00bs: http://www.runoffgroove.com/fetzervalve.html It has the required data for a J201 too
Thanks again!!!
Thanks again!!!
- estragon
Hi, that Fetzer Valve article is exactly where I took the J201 values. Really handy.briggs wrote:Thanks a bomb Estra, I've been fiddling with that Excel thing for about an hour now trying to work out what all those symbols were... I'm just moving into learning all about Fet and the like, I've done opamps - fully versed in their operation. I've been reading this too - a good resource for Fet N00bs: http://www.runoffgroove.com/fetzervalve.html It has the required data for a J201 too![]()
Thanks again!!!
I noticed that changing the drain resistor to 22k is not really necessary. In my spreadsheet the "R" value didn't fit in the cell and appeared as "####", thus I assumed it was invalid. Now I noticed it is a problem with the cell being too small to display the value. 100k drain resistors do work here. Too small resistors may give a negative value for "r".
In this example it is interesting to put a 12k drain resistor, as this makes the "r" vanish to 0, so you omit one resistor.
- briggs
So would it be best to stick in a 100k trimmer for the biasing of the fet drain to 6v?
I'm looking forward to playing with this tomorrow. I've got to read up that fetzer valve article fully, it looks like just what I need to understand these little bastard Fet's! At the moment I'm completly lost....
I could be completely off but, that looks just like a booster but with a lone clipping diode at the input. The full schematic, http://www.sugardas.lt/~igoramps/articl ... age090.jpg, looks like three of them in series after the first booster w/o diode. Looks interesting.briggs wrote:...
- briggs
There's some interesting stuff here about tube emulation http://www.pritchardamps.com/pritchardamps.cfm
- soulsonic
That diode is for biasing, not clipping.
In the text, it says that the diode should be a low voltage-drop type; either a Schottky or a germanium. I'd use a germanium for extra mojo.
Viktor Kempf is the MAN! I highly recommend all his articles that can be found at http://www.rusblus.ru
Just click on stuff until the tech articles come up - that's what I did!
I believe these are the original articles that Igor based his on.
I'm planning on having my own version of these ideas in my blog sometime. I understand Russian well enough to be able to "read between the lines" of the garbage Babelfish translation to get what's going on. My understanding of Russian vocabulary is very poor, but I can read the alphabet well and I've come to realize that many electronics terms are very similar phonetically to the English equivalents. It comes in handy when translating Russian transistor and valve datasheets.
I really love the ideas presented in these articles, and I think it's important that we give them a serious look. Viktor has done alot of really good work and I think it's something that deserves to be shared. Thanks for starting this thread up Briggs! I've seen it mentioned here and there, but no one's really followed up with a deep discussion of it.
