Boss True Bypass
Check it out:
That's what I'm talking about... true bypass without hacking up the box!
Made me a little board for it:
I wrote an article about it in my blog.
https://solgrind.wordpress.com/2009/04/ ... -for-boss/
Silent Fly
Has thanked: 27 times
Been thanked: 47 times
Post by Silent Fly »
Very cool stuff Soulsonic! [smilie=a_bravo.gif]
I would add some more pictures of the component side of the board.
It would also be interesting to see the millennium bypass and switch connections in a generic edited Boss schematics. I think it would help a lot in the understanding of how you implemented the idea.
Thanks for sharing. :thumbsup
Greg
Completed builds: LOTS..
Has thanked: 64 times
Been thanked: 163 times
Post by Greg »
That is clever and very Trick !!
You're a real innovator Soulsonic.. :thumbsup
Thanks guys!
For the LED switching, I used the "Millenium 1" with a JFET because it has the least number of components. I used a J201 and it works great - though in the original article R.G. said the JFET Millenium does this slight fade-in thing on the LED, but with the two that I've done so far, the LED comes on instantly without any noticeable fade-in. Maybe it has something to do with using a higher-current LED?
I will see about drawing up something to illustrate how these kind of bypasses are done... but it's fairly straightforward and simple. I removed the two transistors for the flip-flop to disable it, and I replaced the switching FET with a jumper. Then, it was just a matter of hooking up the I/O wires to the bypass switch in the usual way.
Has thanked: 218 times
Been thanked: 857 times
Very sweet!
puppiesonacid
Been thanked: 12 times
Post by puppiesonacid »
brilliant!
Spazzmatazz
Post by Spazzmatazz »
Soulsonic making history!!
an elegant solution... of course (I prefer non drilled boss with no true bypass).
Is a great Boss pedal Update!!!
PCB?? or stripboard?? Thw whole world needs it!
Silent Fly
I put together a schematic that shows the Soulsonic’s True Bypass implemented starting from a Boss DS-2.
I hope you will find it interesting.
cpm
Been thanked: 50 times
Post by cpm »
thats nice if the switch is dpdt
other pedals i've seen use an spdt so it not so easy
cpm wrote:thats nice if the switch is dpdt
You must replace the stock switch with a miniature DPDT. That's what the small board is used for - it holds the switch and the JFET circuit for the LED switching. I did the first one on plain perfboard; it's very simple. The only trick is getting the height of the switch adjusted so that it will actuate correctly with the foot treadle.
minatour87
Post by minatour87 »
thanks for the information, i wanted to mod an old american metal pedal
peace minatour87
rasta_maleek
Has thanked: 52 times
Been thanked: 52 times
Post by rasta_maleek »
have anyone the schematic corrected? i think that the old attachement is not the soulsonic one.
thanks a lot for share
Jack Deville
Completed builds: too many. too many.
Been thanked: 86 times
Post by Jack Deville »
Hi!
There is a quick way to defeat the flip-flop circuit used in BOSS effects by simply pulling one resistor.
The circuit and defeat is detailed here, Page 3:
http://jackdeville.com/manuals/click_le ... _guide.pdf
Omit Click-Less™ True-Bypass installation and substitute your switch of choice!
:horsey:
I'm a "professional."
Buy my products and make me rich.
www.jackdeville.com
rasta_maleek
thanks for the info jack.
Always grettings
Ivan
