Measuring FET pinch off voltage?
- DimebuGG
How am I suppose to measure FET's pinch off voltage?. Is this referred as the cutoff voltage(Vds)?..I'm assuming the V+ at the drain while the common(GND) is at the source. Am I right?..
- B Tremblay
- DimebuGG
spot on!..B Tremblay wrote:http://runoffgroove.com/fetzervalve.html#11
shame on me,i didn't notice it earlier..thanks..
oops, i'm about to use 24V DC as my supply voltage..what's the proper value between 1M-10M resistor shall be used?..sorry
- briggs
That is one of my favorite articles. It's got a lot of very useful info thereB Tremblay wrote:http://runoffgroove.com/fetzervalve.html#11
- DimebuGG
I have a question Mr. B Tremblay.
Does the selection of the appropriate Drain and Source resistors applies to each stage of a high gain FET circuits?
- B Tremblay
If you've determined the optimal values with the calculator on the Fetzer Valve page after measuring several FETs, then you could use the same values for each of the stages, provided that you use FETs with reasonably close Vp and Idss numbers. There will usually be a group that are close.
- DimebuGG
Yeah, I did. I kinda keep the individual values of Vp and Idss of each FET and marked them accordingly. These are J201's and 2N5458's. Strangely, unlike those high gain FET emulation circuits usually have an Rs at 1.5K - 4.7K but to those I tested never reached 500 ohms at all. My supply voltage again is 24V DC.
- B Tremblay
I'm not quite understanding what you mean. What was the average Vp and Idss for each type of FET?
- DimebuGG
Well, I made a mistake in J201's Idss, so here the corrected values:
I tested only 4 devices of each type.
J201
Vp(ave.)= -0.8875, Idss= .6125
2N5458
Vp(ave.)= -1.86, Idss= 2.705
Actually, I have the individual Vp and Idss of each FET.
J201 Vp / Idss
A. -0.76 / 0.55
B. -0.85 / 0.47
C. -0.97 / 0.82
D. -0.97 / 0.62
2N5458
A. -2.49 / 6.2
B. -1.57 / 3.1
C. -1.35 / 2.5
D. -2.03 / 4.6
J201
2N5458
J201 Vp / Idss
A. -0.76 / 0.55
B. -0.85 / 0.47
C. -0.97 / 0.82
D. -0.97 / 0.62
2N5458
A. -2.49 / 6.2
B. -1.57 / 3.1
C. -1.35 / 2.5
D. -2.03 / 4.6
- B Tremblay
If you plug those numbers into the calculator, then you can see how two FETs with close measurements will perform. For example, I put in your first J201 with Vp of -.76 and Idss of .55 and with a 24V supply, the gain will be 24.1dB with Rd of 36k7 and Rs of 1k1. Of course, you will need to decide whether you use 1% or 5% resistors to get close to those values.
What is your overall design goal?
- DimebuGG
Oh yes, I already had their respective Rd and Rs. It's not really a stompbox(well maybe yes) but I was thinking then of creating a dual channel SS preamp in a DD size enclosure. It's basically based from some high gain FET circuits and maybe the Fetzer Valve itself as the clean channel. That Fetzer Valve article is a very interesting and informative read. Thanks man!. I should have read it before!!
