Reading Mosfets
travsbluz
Has thanked: 17 times
Post by travsbluz »
Hello again.
I've spent the last couple of days learning how to use my new breadboard. I've been able to make all but a couple of things work so far. Two of them use BS 170's. I assume that I am reading them off of the schematic wrong.
Could someone show me, or lead me to a labled schematic symbol. Labeling Drain, Source, and Gate.
All help is appreciated.
Thanks for your time,
Travis
Scruffie
Has thanked: 28 times
Been thanked: 169 times
Post by Scruffie »
http://www.datasheetcatalog.org/datashe ... ijs5ky.pdf
Heres the data sheet, just type the part name followed by datasheet into google and you should be able to find it fairly quickly in future.
Scruffie.
travsbluz
Post by travsbluz »
Thanks for the information. That will come in handy I'm sure.
I am also looking for something that shows the Schematic symbol labled as to which line is which pin. I will try some more searching.
Thanks again for your time,
Travis
