Making connections on Perf Board
kurotenshi
Post by kurotenshi »
When ever I se something made on a perf board, the solder side of the board show conections either made with someting that looks like solder tracks or with un insolated wires. What i'd like to know is how do you guys usualy make the "tracks" when using perf board.
IvIark
Has thanked: 561 times
Been thanked: 586 times
Post by IvIark »
Component legs can get you most of the way there.
Greg
Completed builds: LOTS..
Has thanked: 64 times
Been thanked: 163 times
Post by Greg »
I sometimes use a Zero Ohm Resistor too.. esp. if it's a long link.
willc1968
my favorite amplifier: Kustom K 200 A-4 in red
Completed builds: kay fuzz, clark fuzz, ea tremelo, green ringer, tremelus lune, a few big muffs, fuzz face and factory, sft, woolly mamoth, a bunch of tonebenders and many more that need to be boxed
Has thanked: 20 times
Post by willc1968 »
perf board is my prefered when doing a proto of something. just about all the time the component leads will be more than long enough without having to use jumpers. if i am using a lot of socketsonthe board i do use insulated wire for run over 1/2" or so.
kurotenshi
thanks guys, i've tried that technique in a build and, as far as i know, things are going well.
