I first time to do it, i don't know is yes or not work
HelloGila_Crisis wrote:here you'll find my layout for Takeda's MS20 VCF. I added a charge pump to use it as a stompbox with a standard 9VDC power supplies (also with -/+9V instead of +/-15V the filter works really well! but you can omit the charge pump part of course).
Hi, yes this is the LP part only, but you can easily modify it to have the HP as well. The layout is the same, you only need to change the input/output routing from/to the filter. With this layout I've build a unit with the MS2 HP > LP configuration and it works like a charme!snk wrote:Hello
Thank you for your layout.
As far as i see, there is not LP/HP switch, right ? It is "only" the MS20 lowpass, not the hipass, right ?
Is there any layout with both filters in serial ?
