High's boosted? That's not the impression I got!neilnil wrote:Finished up this one a while ago. Highs seem boosted a bit too much. Maybe larger compensation cap would tame it? I don't know. Other than that, sounds pretty decent. I think I'm gonna let this do high-gain job for me for a while, instead of a LDO clone I've been using, which has less highs and more mids. And I recommend to try log taper for tone pot, that gave me better control.
Jun
BJFE - Dyna Red Distortion [traced]
- soulsonic
Thanks! I guess a "stock" 100n cap in the feedback loop caused it. I put a socket in there and tried different values and it changed the tone drastically. 0.47u as in the reversed pedal was too much for me. I sticked a 200n and now I'm happy! Timmy bass control would be a great idea indeed.soulsonic wrote:High's boosted? That's not the impression I got!neilnil wrote:Finished up this one a while ago. Highs seem boosted a bit too much. Maybe larger compensation cap would tame it? I don't know. Other than that, sounds pretty decent. I think I'm gonna let this do high-gain job for me for a while, instead of a LDO clone I've been using, which has less highs and more mids. And I recommend to try log taper for tone pot, that gave me better control.
Jun
Jun
After seeing the Dyna Red schematic, I bought a CA3130EZ and put that in my Rat2. Real nice. The LM308N that I put in a while back, won't be going back in (most likely at this stage).soulsonic wrote:An LM308 is completely different inside than a CA3130. I expect they would sound worlds apart. For one thing, the CA3130 is almost entirely MOSFET, whereas the LM308 is entirely bipolar transisitor.....
- picassochild
Could you explain differences in tone/gain with CA3130EZ instead of LM308? I'm gonna send few pedal for upgrade to Soulsonic and had idea to try CA3130EZ in RAT without scheme changes. Let us know about it.grolschie wrote:After seeing the Dyna Red schematic, I bought a CA3130EZ and put that in my Rat2. Real nice. The LM308N that I put in a while back, won't be going back in (most likely at this stage).soulsonic wrote:An LM308 is completely different inside than a CA3130. I expect they would sound worlds apart. For one thing, the CA3130 is almost entirely MOSFET, whereas the LM308 is entirely bipolar transisitor.....
- Greg
The Gain is a function of the circuit design, not the opamp.
Is neilnil's layout the original version or the one with more low mids?
Sorry if it's already has been said, havn't been in here for a while.
Btw, wy are there double values on some components in the schematic?
Cheers/Ben
Cheers/Ben
- Duckman
- Opamp Operator
So... since CA3130 and LM308 got same in/out, is that enough to switch between them? No other considerations need be made?
Please, tell us about the differences you ear/feel, if you don't mind.
The sound is much more useable for me. Tighter, less messy on the bass. I really like it. I was having a problem where high output humbuckers would kinda overload the bottom-end when played hard. I modded the Rat slightly to reduce the bottom end slightly (and also another tweak), but swapping to this IC resolved the issue for me. I probably should try reverting the other mods now - but it sounds pretty good to me.picassochild wrote: Could you explain differences in tone/gain with CA3130EZ instead of LM308? I'm gonna send few pedal for upgrade to Soulsonic and had idea to try CA3130EZ in RAT without scheme changes. Let us know about it.
I reckon perhaps you could simply install an IC socket and try a CA3130EZ if you like.
- soulsonic
This is the artificial ground that is standard in single-supply opamp designs. You see this in the majority of stompbox designs.TheLemon wrote:On the original schematic what is the "Bias" that goes from the 22uf electrolytic cap?
- TheLemon
How would this translate in the circuit? Would this go to ground? I've only made a few dirt boxes but none have had this.soulsonic wrote:This is the artificial ground that is standard in single-supply opamp designs. You see this in the majority of stompbox designs.TheLemon wrote:On the original schematic what is the "Bias" that goes from the 22uf electrolytic cap?
- Greg
It connects to the 360K resistor at the input.TheLemon wrote:How would this translate in the circuit? Would this go to ground? I've only made a few dirt boxes but none have had this.soulsonic wrote:This is the artificial ground that is standard in single-supply opamp designs. You see this in the majority of stompbox designs.TheLemon wrote:On the original schematic what is the "Bias" that goes from the 22uf electrolytic cap?
- candletears7
Is there any benefit in running this circuit at 18v, like, eg: an OCD? Can the originals take 18v+? I've not heard an original DRD so not sure if it would make a hell of a difference in headroom. Just thought I'd ask before I perf up that JL layout with lower voltage electrolytics....
- Greg
NO.candletears7 wrote:Is there any benefit in running this circuit at 18v, like, eg: an OCD? Can the originals take 18v+? I've not heard an original DRD so not sure if it would make a hell of a difference in headroom. Just thought I'd ask before I perf up that JL layout with lower voltage electrolytics....
Max supply voltage of the opamp is 16V.
- candletears7
Cool! Thanks.Greg_G wrote:NO.candletears7 wrote:Is there any benefit in running this circuit at 18v, like, eg: an OCD? Can the originals take 18v+? I've not heard an original DRD so not sure if it would make a hell of a difference in headroom. Just thought I'd ask before I perf up that JL layout with lower voltage electrolytics....
Was about to check out that opamp data sheet but i haven't had time to find it. Trying to do fun stuff at work is a bitch!
- candletears7
quick question - on the JL layout, what does 'D23' up near R1 designate? Just curious...
- candletears7
of course. oops.
