Stompbox order in pedalboard
elektratone
Post by elektratone »
I've been thinking pedalboard where one can change signal order with somekind of switch panel.
Let's say we have 3 pedals in a board, board has mounted cables for pedals like:
pedal1 in, pedal1 out
pedal2 in, pedal2 out
pedal3 in, pedal3 out
then there this panel where you can choose where pedal1 output should go, something like this:
guitar signal goes to pedal1 in
pedal1 out goes to pedal 3 in
pedal3 out goes to pedal2 in
pedal2 out goes to amp
that way, one can layout pedals whatever order he/she wants without cables going all over the place
Any ideas how this can done in a "right way", maybe dips, relays, jacks?
-E-
JiM
Proco Rat
Hot Harmonics
Crackle Not OK
Has thanked: 69 times
Been thanked: 65 times
Post by JiM »
With three loops you can swap the first two, then swap this lot with the third one.
You can do that mechanically with two of these : http://www.beavisaudio.com/techpages/Pe ... itcher.htm
Or modify relay-based A/B switches : https://www.freestompboxes.org/viewtopic.php?f=11&t=2709
