Kaputepalla - Memory Man project
sadrew
Been thanked: 14 times
Post by sadrew »
congratulations for the great build and thanks a lot for updating the layouts, i will use them in a very near future.
borislavgajic
Has thanked: 131 times
Been thanked: 277 times
Post by borislavgajic »
:thumbsup :applause:
thank you.........it was a big project.......
now we could go to attack decay .... :?: what do you think???
boris
Rocket Roll
Been thanked: 38 times
Post by Rocket Roll »
borislavgajic wrote:now we could go to attack decay .... :?: what do you think???
Brrrrring the noiZe! :applause:
Started this thread to get an 'This topic doesn't exist' message at the old url.
Rocket Roll
Could someone help me with the values of C19, C20, C16, R38, R39, R42?
I've discussed this schematics with a friend, and he considers the values given for those elements to be weird. Were they different in earlier schematics?
Has thanked: 218 times
Been thanked: 857 times
They might be a little odd but perfectly normal to buy.
Zokk
Has thanked: 211 times
Been thanked: 68 times
Post by Zokk »
Have you adjusted the clock cancelation trimmer?
it's maybe this noise you are hearing.
If you have not done it yet, so you should perform these procedures:
Zokk
Post by Zokk »
They call it clock balance trim in this document.
kugua wrote:yeah, I tested my circuit.so I think the noise is come from the NE570 expand circuit.the noise is like hiss in background.so do you can recommend some idea for me to reduce some noise .thanks
I remember someone recommended to use shielded wiring to reduce clock noise
Cloud10
Post by Cloud10 »
modman wrote:Kaputepalla sent me these files, because he cannot post links. It's a modded EH Memory Man for double delay time.
Still looking for a corresponding schematic.
Haven't looked anything over yet, killer contribution anyways.
It's all yours to further comment on Kaputepalla...
Any chance someone might re upload the ANALOG DELAY X2TIME MOD.pdf file? Thank you in advance for any help!
cellchains
Post by cellchains »
Sorry to be digging up, but I just wanted information, on the 24v power supply, is the positive on the ground?
Davidgilmour90
Post by Davidgilmour90 »
hello everyone, I see that the post is a bit old, I hope someone can answer. Have any of you ever tried to build Zokk's Memory Monkey deluxe version of the memory Man? (his PCB) do you know if it is verified? I tried to build it but it doesn't work (I have already corrected the missing link on the power supply diodes). Does anyone know more about it if the PCB is otherwise ok?
I attach the project HERE:
DeluxeMemoryMonkey.zip
(217 KiB) Downloaded 35 times
I've attached the files a jpgs for easier discussion.
But the source is here: it's unverified
Davidgilmour90
Hi Modman, thanks for answer. I checked memory monkey project and unfortunately various parts in the layout are wrong in the Memory Monkey layout.
I'm going crazy correcting them, I'm trying. There are various tracks with missing links and bad links to correct. If needed, I can post the corrections, the volume of the effect part higher than the dry part remains. Could someone help me finish debugging?
if anyone is interested I can post the corrections :shred:
Davidgilmour90
Someone can kindly confirm me if this is the right scheme and if all the values ​​are correct? I'm taking this as a reference. I attack it below. :worship:
EHX DMM Factory Schematics.pdf
(39.46 KiB) Downloaded 38 times
