How can I make my BOSS DD-3 always ON for mod it to true-bypass?
BOSS DD-3 always ON
- Dirk_Hendrik
The DD3 exists in 3 versions. Which one is yours?
see also:
http://www.stinkfoot.se/andreas/diy/articles/DD3.htm
(excellent stuff)
see also:
(excellent stuff)
Mine is DD-3 version 3.Dirk_Hendrik wrote:The DD3 exists in 3 versions. Which one is yours?
see also:
(excellent stuff)
- Dirk_Hendrik
In that case... sorry. Can't help you with that. I haven't had one on my bench yet.
A possibility would be a relay controlled True Bypass. I have made test way to a BD 2.
regards Uwe
regards Uwe
- pz
probably something similar or the same as in DD5 - bypass is done in digital domain, that is, in bypass mode DSP/uC spits no signal to DAC.alsercol wrote:There is no FETs on DD-3. Switching of DD-3 is different than other BOSS pedals.
The only one solution i see here would be some additional circuit that checks if the Check LED is on, when not - it should simulate a click on the bypass switch. The LED signal is only one point where we can easily check if delay is on or off.
just speculating, a haven't seen the component side of the new DD3 pcb...
