RMC - RMC1 Wah (Geoffrey Teese)
JHS
Been thanked: 5 times
Post by JHS »
Who needs it?
The only interesting things for me on his site are the Rocker and the Fillmore Wah (if they don't have this useless crap in it like the RMC-Wahs).
JHS
MoreCowbell
Been thanked: 15 times
Post by MoreCowbell »
JHS wrote:Who needs it?
The only interesting things for me ....
Thats a fairly self centered statement. Just because YOU aren't interested doesn't mean somebody else isn't.
I'm not really into wahs, but AG making the effort to take and post gut shots is appreciated.
Bernardduur
Has thanked: 89 times
Been thanked: 645 times
Post by Bernardduur »
Schematic of a RMC RMC1C wah I had on my bench : see here
All resistors are metal film expect for the CC which are carbon comp. 220n caps are MKT, others are MF. Transistors are metal cans with no markings.
devastator
Been thanked: 22 times
Post by devastator »
thanks ! :D
CHEEZOR
Has thanked: 42 times
Been thanked: 47 times
Post by CHEEZOR »
Very cool. Thanks everyone! :)
JimiB
my favorite amplifier: AC30
Post by JimiB »
What its not a digital delay being marketed as an analog with tap tempo?
The RMC1 I had in my hands recently had a BC108B and a BC108C in it.
Bernardduur wrote:Schematic of a RMC RMC1C wah I had on my bench!
nice one!
I think there might be a mistake in the schematic. Shouldn't the output connect to the "hot" lug of P1, not the wiper?
Thanks for tracing! :D
Bernardduur
Woops...... shouldn't make schematics late at night :D
New schematic
jt
Has thanked: 21 times
Post by jt »
Thanks Bernardduur
R.G.
Been thanked: 39 times
Post by R.G. »
I think there's another mistake or two.
As shown, I think the 10uF C3 would eat all the signal from the feedback path of the first transistor and kill any wah effect. I think the connections of L1, R6, R7, R8, C3 and C4 are a bit scrambled.
ryanuk
Has thanked: 29 times
Been thanked: 28 times
Post by ryanuk »
R.G. wrote:I think there's another mistake or two.
Agreed - the error is the R7 connection.
R7 should be disconnected from R5/L1/R6/C3/R8 and then connected to the junction of R6/L1/C4
Check out this link...
http://www.effector-repair.com/index.ph ... _WizardWah
I realise this is for the Wizard Wah and so values may differ, however, the outline anatomy and layout should be the same. I've been meaning to draw up a schem from the pics on this page for ages. (I think Bajaman beat me to it with this Baja Wizard Wah Wah photo essay).
RyUK
Bernardduur
Woops; completely true! I REALLY should try my tracing when I am not in a hurry :D
Ed G.
Post by Ed G. »
Ok, so what's the deal with the 10pf caps? Looks like some local feedback to reduce high end? Personally, I can't get ENOUGH high end out of a wah. I don't go full toe-down that often, but when I do, I want to inflict PAIN on the audience.
phibes
Has thanked: 75 times
Been thanked: 189 times
Post by phibes »
Help stop radio interference.
Image Ken
Ed G.
Post by Ed G. »
Seems like radio interference is most likely to come through the inductor. Why not cover the inductor with a shield of some sort and ground it?
Ed G. wrote:Seems like radio interference is most likely to come through the inductor. Why not cover the inductor with a shield of some sort and ground it?
This could be true with a plastic case. But a serious wah is in a metal case which shields the inductor from RF itself. The RF induced comes via the cable and therefore the ampification at radio-frequencies is reduced with such a capacitor.
Here are some tips against RF from the Audio Handbook by Dennis Bohn:
AUDIO RECTIFICATION
Or, "How Come My Phono Detects AM ?"
Audio Rectification Elimination Tips:
- Reduce Input impedance.
- Place capacitor to ground close to the input pin or base (~ 10 -300p).
- Use ceramic capacitors.
- Put ferrite bead on input lead close to the device input.
- Use RF choke in series with input (~ 10µH).
- Use RF choke (or ferrite bead) and capacitor to ground.
- Pray.
In the picture below you can see that some people already tried to screen the inductor. They used conductive silver, but I think with restricted success.
