Hi guys (and gals?),
here is the complete bundle to do a (more or less authentic) clone of the Maestro MP-1 Phaser.
The pcb should fit a BB-sized enclosure. The layout is more of a form follows function approach...
. It is rather tightly packed with all those standing resistors in order to get it down to this size. Solder the three jumpers first (marked red), especially the one under IC4. After that the flat resistors and the sockets for the ICs. The square pads of the pots correspond to lug 1. For the adjustment of the trimmer take a look at the service manual that you can find
here. I can't really tell which FET would be best to use. The one I specified, is just used for the layout because of it's common pinout. But probably most of the commonly used FETs will work if you watch the orientation.
With 24mil track width the minimum clearance goes down to 9mil. Just in case this is too tough for some of you home etchers, I could generate an etching template with less track width, resulting in a bigger minimum clearance. That's no problem.
If something should be unclear let me know.
Cheers and happy phasing,
Volker
