BH 420 bass amp; Help making a pcb layout
chicago_mike
Has thanked: 22 times
Been thanked: 316 times
Post by chicago_mike »
Hey all.
Okay I have a schematic of the venerable AMP BH 420 bass amp. This is the father of the EDEN, SWR, Thunderfunk and a few others.
What I want to do is make a pcc layout, but I could use some help as this is my first real try. I am all for posting the layout here as well. :)
One of the images is a pcb "see thru" so someone with a little skill in this could create one.
I would like to change 2 things:
1. Change the enhance switch to a pot
2. Raise the freq. of the treble control
I think this would make a great project for us bass players and for home stuio cats as well. 8)
For services rendered I can offer parts, icecream, snickers, cuban sluts...you know...the norm around here..
Skyline FX 2013
chicago_mike
Sorry for the GIANT sizes...
also heres the PREAMP schematic..the first is obviously the power amp..im not interested in that..its too old.
Skyline FX 2013
chicago_mike
Friendly bump and a real Chicago pizza to any and all who would like to help with this bad boy. :)
Skyline FX 2013
gus
Post by gus »
I would buy a big solid state power amp for the power amp section.
The preamp looks to be maybe what people might like about this amp.
LImiting
EQ
high and low outputs
Preamp treble adjust C17
Are the preamps C7, C21, C22 and C28 tantalum caps?
preamp Q1 might need to be selected, need to check the specs of the JFET and work out the limiting design.
D2,3,4,5 are part of the clipping detecting nice how the diodes allow four stages to be sensed for clipping
What parts do people like?
chicago_mike
The whole preamp section, limiter, eq, tone balance.
This bass amp inspired the SWR, Eden, Thunderfunk crew.
I want to build just the preamp section. I do believe they're tantalums the ones, you mentioned.
Im going to have a go at eagle cad, but it does seem a little overwhelming. :oops:
I also have a pic of the layout I can upload. gimme a few. :)
Skyline FX 2013
chicago_mike
Skyline FX 2013
Duckman
Has thanked: 320 times
Post by Duckman »
Interesting. I'm starting my own PCB.
Duckman
Post by Duckman »
Well, almost done, but have some notation problems:
"Note 3: All * items may be 1/2 impedance shown"
Those items are some pots, resistors and two caps... Should I understand that as the half of the nominal value? Maybe in resistors, but .... in caps?? :scratch:
Other one: two caps in the power section are labeled as "10 x 2" What does it mean? 20uF or two 10uF? :scratch:
Sorry 'bout my noobness :oops: but any help will be really appreciated.
lietuvis
Has thanked: 95 times
Been thanked: 83 times
Post by lietuvis »
Duckman wrote:Interesting. I'm starting my own PCB.
I have this picture if that helps to anyone
Duckman
Post by Duckman »
Great! Do you have some picture of the component side, to confirm those values mentioned above?
Mmmm... maybe I can follow the routing to see what I get, but just the resistors, not the caps.
ppluis0
Has thanked: 121 times
Been thanked: 278 times
Post by ppluis0 »
Duckman wrote:Well, almost done, but have some notation problems:
Hi Duck,
The potentiometers marked with asterisks are only those belong the EQ section ?
Or there are asterisks in other places of the diagram that I can`t see ?
All these pots are conected in parallel at the (+) and (-) inputs of an opamp. With the wiper at center there is no gain and no attenuation of each band, and you obtain boost or cut at each end, same as we expect of any graphic EQ
Doesn`t matter if ALL of them are of 100 or 50 K, but the taper MUST be linear.
This is an interesting EQ design as each freq band is also tunable in frequency.
You are intended to reproduce all the features of this design ? (limiter, enhancer, XLR out, bi-amp out, clipping indicator) or just plan to use the neccesary functions and leave the rest ?
Muchos Kudos,
Josè
Duckman
Post by Duckman »
Hola, Pepe
Thanks for your advices!
Not just the EQ section pots; look around the tone balance pot (upper right): R57, 58, 59 (pot), 60, and 61 are marked, but C29 and 30 (.01 each) are also marked :!: hence my question. How should do I interpret that "half impedance" note?
ppluis0 wrote:You are intended to reproduce all the features of this design ? (limiter, enhancer, XLR out, bi-amp out, clipping indicator) or just plan to use the neccesary functions and leave the rest ?
I'm going for the whole 420 pre package. I finished (almost) my ExpressPCB version of the preamp section, but I want to be sure about the correct values.
Any way and as you said, isolate the EQ section for a stand alone unit it's a good idea, but, by now, not for me. I was checking the gyrator values with the Muzique's calculator that you can find here http://www.muzique.com/lab/gyrator.htm and maybe I'll do some adjustements in the frequency ranges.
Saludos!
ppluis0
Post by ppluis0 »
Cómo estás, Pato ? (I´m sure that this forum will benefit if adopt more spanish words... :lol: )
Perhaps the designer think that the parallel connected potentiometers belonging the EQ section can be all of 100 K or all of 50 K, but the componentes surround IC7B must be halved in value if were need to use half the pot value. I think that is a benefit at time to buy components.
After see the dimension of the board in the photograph posted yesterday, my best guess is that two decoupling caps at each supply (C38 and C39) must be placed somewhere in the rail traces to avoid any noise.
Muchos saludos,
José
Duckman
Post by Duckman »
Err :scratch: Ok, but... What about "1/2 impedance"? How this concept must be applied to caps? I'm lost about that! :(
Maybe I should use the stated values. :hmmm:
Abrazo.
ppluis0
Post by ppluis0 »
Buenas noches, (good night)
I imagine that in case of not to have 100K pots in stock, at time to solder, a batch of preamps fitted with 50K pots works equally well.
(There is also a break to the people at the purchase dept... :D )
But the only position at which some components vary as a function of the pot value is near IC7 b
I`m agree with you in your perception to use the stated values. Also is reccomendable to place among the two pairs of 10uF electros, some 100nF caps from each supply rails to ground at several places of the pcb, due the great area needed by the board.
Perhaps the long supply tracks can act as antenna and electrolityc caps are not enough to shunt rf noise as little ceramic caps.
Salud (cheers)
Josè (Joe)
Duckman
Post by Duckman »
So, after googling about capacitors impedance
Capacitors are different from resistors and inductors in that the impedance is inversely proportional to the defining characteristic, i.e. capacitance.
That means I have to double the value in both .1 capacitors to .2 (.22 in fact) to obtain "1/2 impedance", right?
Any way, looking in detail the picture posted by lietuvis, you can see two 47k resistors near the Tone Balance pot (third from R to L) where R58 and R60 must be, wich is the value stated in the schemo, so I'm going to use these values and forget all that "1/2 impedance" shit :horsey:
I'll post some pictures when finished.
Meanwhile, thanks ppluis, lietuvis and the rest of the bunch :thumbsup
ppluis0
Post by ppluis0 »
Duckman wrote:So, after googling about capacitors impedance
Another legendary preamp to build is the Ampeg SVT, that has been reissued as rack unit alone (don´t remember now the exact model name), but employ a specially wounded inductor in the midrange EQ that I think is a difficult to reproduce to attempt a clone.
I look forward to see your layout finished :horsey: (I don´t know what this smilie means, but looks funny...)
Nos vemos luego (See you later...)
José
lietuvis
Post by lietuvis »
José
as for Ampeg midrange inductor you can get it from http://www.sowter.co.uk/. You can actually order inductor with any given specification, the only thing is the price quite high. I paid around £50 for two of them, I ordered 800mH with a taps 100mH and 300mH same as Ampeg. And to my ears they sound so sweet.
Here is my style breadbord to test it, never boxed it up because thinking to install it onboard on my bass.
BTW I used Ibanez eq schematic, but used to control only midrange which in my case all i needed.
Duckman
Post by Duckman »
In case somebody need it... I'm too bussy with the 420 and the CX3 Leslie sim :?
Electronics - Inductors - Homebrew Your Own Inductors!.pdf
(224.66 KiB) Downloaded 88 times
mozwell
my favorite amplifier: home made SVT2
Completed builds: baja tube driver, several TS variants, Sansamp GT2, Ross Comp
Been thanked: 66 times
Post by mozwell »
All
I built my own SVT-2P pre several years ago now, & made my own inductor
RM8 un gapped cores, if you can get some very fine enamle coated wire, you can wind your own.
Here is the one i made & the circuit i used.
You should use a fixed resistor instead of R35 & RV5, as there is DC on the pot (not the best) so its scratchy when it is turned. I normally leave it fully turned up.
I did a pcb layout which i hope you can use. A few others have made this from my pcb art.
If you use the pcb art, make sure you print it 1:1 from the pdf.
Valve preamp BOM.pdf
(13.71 KiB) Downloaded 90 times
pcb_1.pdf
(137.63 KiB) Downloaded 117 times
V_PRE.pdf
(218.61 KiB) Downloaded 115 times
sch_2.pdf
(25.05 KiB) Downloaded 97 times
sch_1.pdf
(34.99 KiB) Downloaded 101 times
inductor svt2 rev 1.pdf
(11.69 KiB) Downloaded 97 times
