As described here viewtopic.php?f=7&t=414&st=0&sk=t&sd=a&start=60 I have two old transformers from an old radio. My aim is to build a Deacy-amp workalike.
One is a push-pull driver, the other is the output one. You can find the schematic in the above link (last page).
First of all, I'd like to say that I roughly understand the purpose of the transformers, but can't figure out what ratios should be used to achieve what they are designed for, so any help is gently welcomed...
But hey, I've made a few measurements, some of them might not be useful, but I may compute the ratio from them?
Driver: measurements done with a DMM connected on the secondary. Do I need an other load?
1kHz - 1V AC RMS at the input : 0.77 V AC RMS at the output (all the secondary winding)
Input DC resistance: 313 ohms - Output DC Res: 302 (all winding again, center is almost half the value)
Output T:
With stock speaker connected at the output: same signal as above: get sound. Output voltage is .0.09V AC RMS.
Input DC res: 0.2 ohms. Output DC res: 8.6 ohms (all winding again, center is exactly half the value, which is crucial according to one of my books))
From the values and sound, I guess that they are in good working order, even if the 0.2 ohms values scares me... I hope I can sort this to make a nice amp project from a "quite" common unit, or simply to update my knowledge and schematics...
Can this help to compute the speaker impedance too (not shown on my shematics)?
Thanks for any help on this, this oldest electronics of mine are the really newest to me...
