The Cheapo Pedal Buyer's Guide
- soulsonic
Check these out:
http://www.gibson.com/en%2Dus/Divisions ... ectsPedal/
I found these for sale today at a local supermarket for about $40 each. The cases are metal and quite heavy.
They also look identical to the "Daphon" branded pedals selling in the UK which Sock Puppet mentioned in another thread.
Could be very useful with some tweaks. I'll try to get ahold of one soon to give a report.
- Dirk_Hendrik
And so thay are. No need looking at the brand names. It' s just the same a s with good 'ol Shin-Ei. You want to add an FX line to your products line. We make em for you with your name on them.
- briggs
- TubeDude22
They look like the Daiphon pedals that were on Ebay a while back.
I got one of the Daphon overdrive pedals off Ebay last year for under $30. If anyone's interested, here's a couple of gut shots:
https://img.photobucket.com/albums/1003 ... rd_top.jpg
https://img.photobucket.com/albums/1003 ... bottom.jpg
https://img.photobucket.com/albums/1003 ... 0D_top.jpg
- soulsonic
Awesome, no SMD! That means these guys can be easily modded.
- NickS
In the USA, search Best Buy for Starcaster - three pedals for Fender's low-end range at around $39 each.
In the UK there's an ebay store, >>Harrier Music<< selling the Daphon stuff at £19.99 plus £4.99 p&p. £18.99 for the distortion. Searching for Daphon finds cheaper Buy It Nows, e.g. flanger for £12.99 + £5 p&p >>here<<.
- modman
- a d m i n
- Has thanked: 4287 times
- Been thanked: 2008 times
I like this thread, so I retitled it from just Maestro Gibson... to
So if you find more cheap pedals sources, please update this link. If you are actually working on one, please share your findings with us in a separate thread.
thanks
thanks
- Dirk_Hendrik
sissysoulsonic wrote:Awesome, no SMD! That means these guys can be easily modded.
- soulsonic
I know... I even own an SMD tweezer iron.Dirk_Hendrik wrote:sissysoulsonic wrote:Awesome, no SMD! That means these guys can be easily modded.
FWIW I can add the Daphon E20CM compressor
https://i273.photobucket.com/albums/jj2 ... /E20CM.jpg
https://i273.photobucket.com/albums/jj2 ... CMback.jpg
https://i273.photobucket.com/albums/jj2 ... 0CMbrd.jpg
https://i273.photobucket.com/albums/jj2 ... CMbrd2.jpg
And The E20GE 7 band Equalizer
https://i273.photobucket.com/albums/jj2 ... /E20GE.jpg
https://i273.photobucket.com/albums/jj2 ... GEback.jpg
https://i273.photobucket.com/albums/jj2 ... 0GEbrd.jpg
S.
S.
Sweet. I've been looking for a US source for the analog delay. I believe they are the same as the Analogman AR20DL:
http://www.buyanalogman.com/AR20DL_Anal ... ar20dl.htm
I've found a guy on eBay who sells them but he's located in Australia.
https://stores.ebay.com/Swamp-Industrie ... idZ2QQtZkm
(They're out of the delay atm.)
Poor picture I know. I'd put everything away before I'd seen it.
The I.C. is an LM3080N. There are also 6 x 2SC1815, 3 x 2SK30A and a 78L09 regulator.
The pedal weighs 628g without a battery.
S.
S.
http://cgi.ebay.co.uk/W-W-NEW-Daphon-DE ... p1638.m122moro wrote:Sweet. I've been looking for a US source for the analog delay. I believe they are the same as the Analogman AR20DL:
S.
- KHELSTROM
I bought the First act Delay from Toys R Us and it was pretty bad. If I remember correctly it used a PT2399 chip. On longer repeat times the sound had this low bit-rate digital crunch soung going on. I ended up returning it and I got the distortion. It dose sound pretty bad but I plan on tracing it and seeing what I can do to tweak it.moro wrote:Also, the First Act pedals at Toys R Us might be worth checking out. At $40, the distortion doesn't seem like a great deal, but the chorus and delay are also $40. I like the enclosures--they seem really sturdy.
Chorus
Delay
Distortion
- soulsonic
What kind of circuit does the E20DL use? A bucket brigade? What is the longest delay time? How are they doing an analog that cheap, regardless of where it's made? Is this waiting to get modded into a DMM?
Thanks! I just bought it.Sock Puppet wrote:http://cgi.ebay.co.uk/W-W-NEW-Daphon-DE ... p1638.m122moro wrote:Sweet. I've been looking for a US source for the analog delay. I believe they are the same as the Analogman AR20DL:
S.
I was saying it looked like the Analogman pedal. He says right on his page that it's the same thing.soulsonic wrote:What kind of circuit does the E20DL use? A bucket brigade? What is the longest delay time? How are they doing an analog that cheap, regardless of where it's made? Is this waiting to get modded into a DMM?
http://analogman.com/delay.htm
So, he swaps out the compander, replaces the stock 3208 for a 3205, adds a few trimpots and makes a couple other tweaks.
