Back to the CC Vibe, I finally went ahead and did my mods, jumping board power to kill the delay and adding a trimpot to adjust the output volume. I haven't built or modded anything since before the 'net was around, having just recently picked up a guitar again after many years without one. (OK I lie I did a few of the usual mods to my TS9 a few weeks ago.)
For the volume mod, I wanted something easily adjustable, and seeing the battery box makes these pedals pretty tight inside I decided to go with a 10K trimmer mounted on the board between the output and power jacks. The board made it simple, I just got out the trusty dremel and hacked out a pad from the big ground surface on the back of the board (after figuring out where my holes would be) :
This gave me my pin 3 to ground point, pin 1/input on the new pad, and I added another hole for the output cable's shield to ground. Pin 2/output is at the top of the pot so I just soldered directly to the lug. Pic is a little fuzzy, but here's a closeup:
For the delay, I just soldered a jumper between the in/out board power lugs on the switch. I like seeing a distinct on/off LED, so I passed on wiring the LED to the speed pot but may add a separate "speed LED" on later. Thanks to the tips here, it all works great!
The only place I messed up was drilling my access hole in the case, I almost did it on the wrong side...just caught myself, but still made a mark in the case...oh well.
