Referering to the components on MarkM's layout:ManCas wrote: My V readings on the TL072 are:
1: 4.03, 2: 4.03, 3: 4.01 (coming from the 1/2V output) 4: 0.00 (To ground)
5: 1.01 (coming from Input), 6: 4.03, 7: 4,04 and 8: 8.08 (coming from V+)
Pin 5 should be Vbias = 4V. You measure 1.01V which is wrong. Vbias should be the "regulated" halve of the power supply voltage that needs to be a stable DC which is critical to the circuit. The Vbias voltage is determined by the voltage divider: R3 (10k) and R4 (10k). It is "regulated" into a stable DC voltage by C2 (10uF) that is parallel over R4. This Vbias is then connected to all kinds of points in the circuit as you ca see in the schematic:
http://www.hollis.co.uk/john/flatline.jpg
as well as in the layout by MarkM.
You can see the trace connecting: R3 R4 C2 Pin5 R2 Sustain-pot-1-2. On all these points, the voltage should be Vbias which should be 4V if your power supply is 8V.
