Hermida/GGG Reverb
B_of_H
Post by B_of_H »
kurtlives wrote:Sounds pretty good, quite convincing.
What brick did you use, the short, medium or long style?
medium came with the kit. It would be fun to play around with the different bricks though, I really think they sound fantastic. even on the demo (which sounds more digital recorded than in person) it doesn't sound a bit digital to me until maxed out.
nihoneiga
my favorite amplifier: 63' Fender Bandmaster
Completed builds: Maestro MFZ-1 (my favorite), 1977 Big Muff, Fuzz Factory, EA Tremolo, Super Hard-on, ROG Tubescreamer
Post by nihoneiga »
Paul Marossy wrote:I put mine into an old tube amp that I have. I think it sounds great!
Paul, you said you stuck this unit into and old tube amp to get some reverb, how did you power it? Battery or adapter or other?
Thanks,
k
nihoneiga
Post by nihoneiga »
I just got this thing built up on perf and I was wondering if the 0 ohm jumper resistors have to really be resisitors or can they just be jumper wires?
kurtlives
Post by kurtlives »
Jumper wires will work just fine! :D
supergigi
Post by supergigi »
which are the size of PCB?
:applause:
kurtlives
Post by kurtlives »
Hate to follow a question with another question....
But, does anyone know the current draw of the GGG reverb?
it definitely sounds like more of a hall type verb. AFAIC it's a different sound altogether than your vintage style spring. it would be hard for me to compare the two side by side as they are very different reverb sounds. i guess it just depends more on personal taste.
Coma
Post by Coma »
You mean the GGG/Hermida Reverb. IMHO it's a def a spring type of reverb.
I have a 66 Super Reverb and usually set the reverb between 2-4 to get a slightly bigger sound and it's where most people set their reverb. I compared the GGG Reverb with my SR reverb and could not tell the difference. If you crank the GGG reverb you will hear the repeats and the reverb will sound like a delay set to sound like reverb but it's not how I use it. I'm not Dick Dale.
nihoneiga
Post by nihoneiga »
Man, so I built this thing up once on Perf and realized I had mirror-imaged the board so the IC feet were hopelessly mirrored.
Then I started from scratch again, built on perf being very careful to make an perfect layout. Got it all together, the reverb brick's feet all soldered in and all I get is super-static with no guitar signal coming through. The static goes up and down depending on how I twist the wet/dry pot.
At this point, if I could just buy GGG PCB I would but they only sell it in a kit so......
Also, of note, I used a BAT 41 diode instead of the BAT 45. And the 5V regulator I got doesn't have a section at the top to solder onto the board like in the GGG instructions. Is that a special kind of regulator? And is it crucial to have that type that solder's onto the board? From looking at the PCB shots it seemed like the top solder was just a point on the board that didn't go anywhere so I figured it was structural.
Could anyone recommend a way to troubleshoot this?
nihoneiga
Post by nihoneiga »
So I've built this thing twice now on perf without success. I've checked layout pretty thoroughly but I wanted to ask about the Voltage Regulator. On the GGG instructions they've got a voltage regulator that has a metal tab at the top that also gets soldered to the board although there is not connection between the tab solder point and anything else on the circuit. What I'm wondering is, in Japan I've only found voltage regulators that DON'T have the metal tab up top, they're covered in plastic so I can't solder it down to the board at that point. What I want to know is, does this make any difference? My thought was that since the connection point isn't going anyway having it attached or not shouldn't make any difference, am I wrong?
Also, any recommendations on a substitute for the BAT diode? Those are pretty difficult to find here too.
Thanks! I really wanna get this thing working....!
jcat5503
Post by jcat5503 »
jfromel wrote:I am building up a stereo unit right now, I am going to add a tone control to each channel as well, should be a fun project.
How do you add the tone control?
newly
Post by newly »
i just build this using the L version of brick. i bought it wrongly..... :slap: :slap: :slap:
it sound a bit thin but i like it.
the only draw back is the sound of bouncing switch....
when i stomp it on....it get a switching noise.....very annoying!!!
Any help to get over this?
culturejam
Has thanked: 432 times
Been thanked: 562 times
Post by culturejam »
newly wrote:when i stomp it on....it get a switching noise.....very annoying!!!
I'm actually working on a version of this with a "tails" function, so that you can switch the effect off and still have the echoes complete. This also should kill the switch pop in tails mode. I'll post details when I get a little further along with it.
newly
Post by newly »
Appreciated.
Barcode
Been thanked: 32 times
Post by Barcode »
Kitarist wrote:Anyone knows what's the difference between the GGG version and the Hermida one ?
I think the hermida has much more reverb on tap than the GGG. (maybe just a different pot or something else?)
Thanks!!!
They are exactly the same...
The Hermida one is the kit you buy from GGG...
culturejam
un chitarist
Post by un chitarist »
if anyone does need pcb (or layout in pdf format) for this reverb can contact me.
Barcode
Post by Barcode »
Kitarist wrote:So can anyone else confirm that Hermida Reverb is actually a 100% clone of GGG Reverb?
I swear it sounds different on the clips i heard :D
I'm not saying it's a clone, I'm saying the two things you are talking about are one thing. You can either buy one that Alf built or you can get the EXACT SAME project on GGG which Alf contributed.
un chitarist
My PCB looks like this:
I can do a great number of pieces at a very good price. We can discuss details via PM.
telecaster
Has thanked: 162 times
Been thanked: 12 times
Post by telecaster »
Just so everyone knows, the asshole above wants $10 for the pdf file of the pcb transfer that he copied from the ggg pcb. :o :shock: :evil: :twisted:
Here is his message to me when I asked for the transfer, not realizing he wanted $10 for it:
Hello!
Thank you for your interest for this PCB. I've used 2 Belton Brick's medium & long Decay. In atachment you can find some sound samples made in this chain: guitar-reverb pedal-amplifier-headfone out (amplifier) - line in PC. Hope you like them.
Price for pdf layout - 10$ (payable via paypal).
Best regards,
Sorin
KindaFuzzy - Looks like a blue nail polish and nutella sandwich.
Freekish - "Our originality is in the basement. Our business is in the toilet"
Guitarlcarl - I did take offence at being called an idiot by a moron.
