anyone seen a mono jack being used as switching jack...
JJ Gabor
Post by JJ Gabor »
Just notice my supa tonebender uses 2 mono jacks.
The ground travels through the 2 sleeve pins and someone has mutilated the contacts as such
As you can see if a jack is inserted the two contacts meet and the ground is connected. Crafty.... cheap bastards!!!. Doesn't look like the sturdiest connection but would probably work at a pinch if you were out of stereo jacks.
Someone must have seen this kind of thing before, but it was news to me.
Paul Marossy
Post by Paul Marossy »
From what I can tell, all of the Colorsound pedals used that sort of switching jack. I think it's just particular to that specific manufacturer.
My Colorsound wah pedal has the same exact jack, and I noticed that same peculiar feature. Never seen a jack like it before I acquired that...
_/\_/\_PJM_/\_/\_
http://www.diyguitarist.net
JJ Gabor
Post by JJ Gabor »
ahhh now i see.
It was made like that. I thought someone had just bent the contacts of a normal mono jack. Interesting.
Paul Marossy
JJ Gabor wrote:ahhh now i see.
Yep, it was made like that. It's very unusual, isn't it?
_/\_/\_PJM_/\_/\_
salocin
Been thanked: 7 times
Post by salocin »
I have a bunch except they're the opposite switcing arrangement, on when unplugged, off when plugged (the pictured one being on when plugged).
