Millenium bypass
AbuseArt
my favorite amplifier: laney lc15
Completed builds: Vox Clyde McCoy
Rebote Delay 2.5
Tube Screamer TS-808
Exotic AC Booster
Marshall Guv'nor
Big Muff Pi
Big Muff Triangle
EH Pulsar
Joe's Simple Overdrive
Post by AbuseArt »
The best way to make true bypass with DPDT switch. My new layout. You can do it like SMD and fix with glue to the enclosure.
verified.
I hope you appreciate it.
BYPASS MILLENIUM.bmp (286.79 KiB) Viewed 5546 times
I like to use a J201 for the FET.
Silent Fly
Has thanked: 27 times
Been thanked: 47 times
Post by Silent Fly »
Very nice - Thanks! :thumbsup
Nikifena
Been thanked: 39 times
Post by Nikifena »
Here is a good information about milenium bypass :
http://www.premierguitar.com/Magazine/I ... ypass.aspx
Actualy I use "normal" schematics with one j-fet. I use cheapest small j-fet for this job, but i have a little pop when I swich between bypass and effect on. Soon I will try this better popless schematics:
rrhoads33
Post by rrhoads33 »
If you placed the diode a bit more on the left side, you won't need Row 5 at all.
There are 10 kinds of people in the world: Those who understand binary and those, who don't.
Whoismarykelly
Post by Whoismarykelly »
Im sure this has been explained somewhere, but now that 3pdts are readily available and under $4 why do people use millennium bypass where you have to add the labor and parts of another board on top of a $4 switch to get an LED to work?
I use it when I do Boss true bypass mods because the tiny bypass switches I use are only DPDT... though they do make a 4PDT version, the DPDT one is easier to get.
And some people live in places where 3PDT switches aren't easy to get.
And maybe you're switching an effect with stereo outs.
And some people think the blue 3PDT switches are junk and would rather use the Alpha DPDT because it's the closest thing they've found to the superior Fujisoku ones that are almost totally extinct.
Barcode
Been thanked: 32 times
Post by Barcode »
and there are some like me who have a bulk of 2n7000 mosfets he got for pennies each and the total sum of parts in the mosfet millenium and a dpdt still add up to about a buck less than using a 3pdt.
Whoismarykelly
soulsonic wrote:I use it when I do Boss true bypass mods because the tiny bypass switches I use are only DPDT... though they do make a 4PDT version, the DPDT one is easier to get.
Gotcha. I knew there had to be cases where it would be an advantage although I figured that the 'people think 3pdts are crap' issue was all going to be pretty big. Thanks!
Paul Marossy
Post by Paul Marossy »
I have built that little Mill 2 Bypass circuit several times, and it never works for me. That makes me feel like a total idiot! :blackeye
But that was years ago when I was first starting out...
_/\_/\_PJM_/\_/\_
http://www.diyguitarist.net
rs
Has thanked: 95 times
Been thanked: 7 times
Post by rs »
I had bad issues with millenium bypass too, but lately i've been allright.
I totally agree with soulsonic, blue 3pdt's are junk, had severall problems with those, on the contrary never had any problems with the alpha ones, i think they are pretty well made, and i've been using them for quite awhile.
Unfortunetly its a bit more expensive than a 3pdt.
jfromel
Been thanked: 8 times
Post by jfromel »
I use it on a mono in stereo out pedal, works like a charm
mictester
Has thanked: 32 times
Been thanked: 825 times
Post by mictester »
Paul Marossy wrote:I have built that little Mill 2 Bypass circuit several times, and it never works for me. That makes me feel like a total idiot! :blackeye
I had problems like that sometimes, and poking around with a multimeter is unlikely to give any useful information because the internal resistance of the meter will affect the circuit operation. I used a couple of 4069BE gates in a "valve sound" circuit, and used the spare inverters to drive LEDs. If you're concerned about the current handling of the CMOS IC, you can parallel inverters - there are six in the package. I used one IC just for the indication, with three inverters on each side of the IC paralleled to drive the LEDs. If you use a bicolour, three-wire LED, you only need one hole drilled in the box for the indicator, and the change in colour looks quite impressive!
[img]
[/img]
Scruffie
Has thanked: 28 times
Been thanked: 169 times
Post by Scruffie »
Couldn't find a vero layout for the millenium bypass with signal shunt, so I made one... orientations are unchecked and it could probably be made alot smaller by someone better at vero layouts than me, think it's okay though but i'm pretty tired.
Schematic here:
http://www.geofex.com/article_folders/m ... l2plus.htm
Input Ground Millenium.gif (14.79 KiB) Viewed 4623 times
Small input from me.
This is Millenium bypass based on AbuseArt's layout with onboard DPDT switch. Next move is to make it with 4PDT to be used with stereo FX's
It's not verified, my first PCB drawing, so be gentle ;) I hope it fits :scratch: :roll:
meffcio
Been thanked: 14 times
Post by meffcio »
Anybody tried it? I mean, is it verified?
Bside2234
Been thanked: 88 times
Post by Bside2234 »
I did the millenium bypass as shown in the Premier Guitar schematic and it pops like mad. I checked it a dozen times and it's all right. I didn't substitute anything. Any ideas? Should I not have grounded it on the DC jack?
mictester
Post by mictester »
Bside2234 wrote:I did the millenium bypass as shown in the Premier Guitar schematic and it pops like mad. I checked it a dozen times and it's all right. I didn't substitute anything. Any ideas? Should I not have grounded it on the DC jack?
OK - which version? There are several. The version with a 1N4148, and any small silicon transistor is the one to go for. Also, does the INPUT of your effect have a high-value pull down resistor? If not, the pop could be coming from there.
Bside2234
Post by Bside2234 »
It's the one in the 4th post from the top with the 1k on the control. I actually thought about the pull-down resistor after I posted. I'll have to try it out.
mictester
Post by mictester »
Bside2234 wrote:It's the one in the 4th post from the top with the 1k on the control. I actually thought about the pull-down resistor after I posted. I'll have to try it out.
OK. Let us all know if that was the problem - it's always good to know when something gets fixed! :)
