Am I that stupid? Veroboard layout advice needd
If I'm looking at a veroboard layout is it supposed to be viewed as if you're looking at the strip side? In other words, when looking at the component side should I reverse it? I attempted to build a Fuzzrite and I'm thinking that I just built it backwards. Fighting back tears. Help!
- RnFR
you are viewing it from the top(component) side. imagine the trace cuts as being on the other side of the board. good luck, i'm sure such things have happened to the best of us in the beginning.
- Greg
Yep... it takes a little getting used to when you flip it over, and you have to be careful when making the cuts, etc.
I often use Vero when making a proto or a one off, but it's really a PITA.
It's slow to build because you're always counting holes and double checking.. and it's pretty easy to get a whisker of solder across a couple of tracks or something... maybe it's the Vero I have, but the masking between tracks is not very effective.
Ok good, I built it as if I was looking through the non-copper side and arranged it as such. Must be bad wiring or soldering somewhere. I'll do some testing and see what's up. All I've done so far are mods. This is my first build from the ground up, so I thought veroboard would be a good start. Is perfboard preferable? I have the supplies to etch my own pcb as well, but I figured I should start simple before taking leaps and bounds. But if it turned out that pcb was the way to go I could be converted. Thanks for the help!
- RnFR
there really is no "best" way. it just comes down to personal preference. vero is good for simple circuits, but you do have to be very careful when laying out and soldering. watch out for bridges. don't be afraid to run an exacto knife down the edges of the strips. then take some rubbing alchohol and wipe of the excess flux and residue that you've scraped off. i prefer pcb's for more complicated circuits, and they are much easier to get right the first time. usually if you take your time, very little debugging of the pcb will have to be done. they aren't that hard to etch, and the only way you can find out is to give it a try. just don't be afraid if you screw up your first etching, and make sure that you have a proper way to drill your boards. a press is pretty mandatory.
- my favorite amplifier: Homemade 18 Watt w/ 2xEL84 and tremolo.
- Completed builds: Big Muff Pi (mostly violet Ram's head with my own bias and impedence mods)
OCD, BYOC OD-2, GGG Tube Screamer, Red Llama, Dallas Rangemaster, Fuzz Face, SHO, Valvecaster, Bajaman's CX-3, ROG 22/7, ROG Professor Tweed, ROG Tri-Vibe, MXR Dynacomp, Mxr Phase 45, Proco Rat (with clippping mods), EA Tremolo, PT 80 Delay so many more... - Location: Austin TX
When I do a vero layout I bring up two copies of the image on my computer screen. Then I flip one horizontally so I have a reference for the trace side too. Good luck!
