Skreddy Lunar Module  [traced]
Damon Jonesta
Been thanked: 15 times
Post by Damon Jonesta »
Very much like the screwdriver except for 3 high gain BC109C's.
http://i42.tinypic.com/1r9maf.jpg
http://i40.tinypic.com/oabw94.jpg
Skreddy
Been thanked: 228 times
Post by Skreddy »
The very first Screw Driver prototype used all BC109C's as I recall. This was before I decided to do away with having each section of the circuit individually switched.
At one point I began using Mena Suvari inside, but that quickly became too expensive.
:lol: :lol: :lol:
that is awesome.
culturejam
Has thanked: 432 times
Been thanked: 562 times
Post by culturejam »
Marc, you are too funny. :mrgreen:
lolbou
Has thanked: 305 times
Been thanked: 220 times
Post by lolbou »
Do you now manufacture in Mexico like Fender Skreddy?
http://fr.truveo.com/doritos-mexican-be ... 1893958775
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
Damon Jonesta
schematic up for grabs and free for all. Enjoy.
Partslist
Part Value Device Package Library Sheet
BODY A100K POT POT custom-pots 1
BRITE B100k POT POT custom-pots 1
C1 10µF 0501 050_020_1 custom-caps-electro-pol 1
C2 100pF 050X030_0252 050X030_025_2 custom-caps-ceramic 1
C3 100µF 0501 050_020_1 custom-caps-electro-pol 1
C4 5.6nF 050X030_0252 050X030_025_2 custom-caps-ceramic 1
C5 4.7nF 050X030_0252 050X030_025_2 custom-caps-ceramic 1
C6 220nF 050X030_0252 050X030_025_2 custom-caps-ceramic 1
C7 470pF 050X030_0252 050X030_025_2 custom-caps-ceramic 1
C8 220pF 050X030_0252 050X030_025_2 custom-caps-ceramic 1
C9 220pF 050X030_0252 050X030_025_2 custom-caps-ceramic 1
C10 100µF 0501 050_020_1 custom-caps-electro-pol 1
C11 15nF 050X030_0252 050X030_025_2 custom-caps-ceramic 1
C12 3.3nF 050X030_0252 050X030_025_2 custom-caps-ceramic 1
C13 2nF 050X030_0252 050X030_025_2 custom-caps-ceramic 1
D1 green LED5MM LED5MM custom-diodes 1
D2 BAT48 1N4148-2 DO35-2 custom-diodes 1
FUZZ A1k POT POT custom-pots 1
PREGAIN B2k POT POT custom-pots 1
Q1 BC109C 2N2369 TO18 custom-trans 1
Q2 BC109C 2N2369 TO18 custom-trans 1
Q3 BC109C 2N2369 TO18 custom-trans 1
R1 56k 6MM.3 R0207/3 custom-resistors 1
R2 470k 6MM.3 R0207/3 custom-resistors 1
R3 18k 6MM.3 R0207/3 custom-resistors 1
R4 100 6MM.3 R0207/3 custom-resistors 1
R5 10k 6MM.3 R0207/3 custom-resistors 1
R6 100k 6MM.3 R0207/3 custom-resistors 1
R7 100 6MM.3 R0207/3 custom-resistors 1
R8 820 6MM.3 R0207/3 custom-resistors 1
R9 100 6MM.3 R0207/3 custom-resistors 1
R10 100k 6MM.3 R0207/3 custom-resistors 1
R11 56k 6MM.3 R0207/3 custom-resistors 1
R12 56k 6MM.3 R0207/3 custom-resistors 1
R13 10k 6MM.3 R0207/3 custom-resistors 1
R14 2.7k 6MM.3 R0207/3 custom-resistors 1
VOLUME A100K POT POT custom-pots 1
Skreddy
Post by Skreddy »
FYI: The above schematic is completely wrong in a number of places. Remember: this is exactly the same topology as the Screw Driver but with different parts.
Damon Jonesta
If you are referring to the missing 100uF on the supply and the reverse orientations of some of the pots, that will be fixed later after i have had a chance to put it on my protoboard and test it out. Some of your labeling doesn't correlate with actual components used and the lug numbering on the pots doesn't match with what is there either. Just plain wrong. My reversal is only as good at best as the "wrongness" of the board. :lol:
Skreddy
Post by Skreddy »
Damon Jonesta wrote:If you are referring to the missing 100uF on the supply and the reverse orientations of some of the pots, that will be fixed later after i have had a chance to put it on my protoboard and test it out. Some of your labeling doesn't correlate with actual components used and the lug numbering on the pots doesn't match with what is there either. Just plain wrong. My reversal is only as good at best as the "wrongness" of the board. :lol:
You traced it completely wrong. Sorry if that sounds like an insult or something. Not my fault you didn't trace it right.
Damon Jonesta
Not insulted at all. :lol: I've re-traced it 3 times and basically got the same thing except for the 100uF at the supply and some orientation issues. Maybe it is wrong... :horsey: We'll just have to see if it's completely wrong like you said, in which case it will sound like a POS, or if it works. If it's wrong then it's the trace, but you can't denied the lug labels on your PCB is in error. Just saying. :lol:
culturejam
Damon Jonesta wrote:Not insulted at all. :lol: I've re-traced it 3 times and basically got the same thing except for the 100uF at the supply and some orientation issues. Maybe it is wrong... :horsey: We'll just have to see if it's completely wrong like you said, in which case it will sound like a POS, or if it works. If it's wrong then it's the trace, but you can't denied the lug labels on your PCB is in error. Just saying. :lol:
If Mr. Skreddy says there are major errors, then it is so. I'm not taking sides here, but history has shown him to be an honest, forthcoming guy. Your effort is still appreciated, however.
And I don't think he said "completely wrong", for the record.
Skreddy
Post by Skreddy »
I won't drag this out; here's the schemo.
C15 and C16 are just alternative capacitor footprints.
Skreddy Lunar Module schematic
Skreddy
Post by Skreddy »
Sorry; my bad. A couple of drinks and I lose all sensibility. :hmmm: It's just drawn differently, but your schemo looks like everything connects to everything else in the right way. :applause:
:lol: :lol: that was good for a larf!! thanks for the schemo! both of you! :applause:
Skreddy
Post by Skreddy »
RnFR wrote::lol: :lol: that was good for a larf!! thanks for the schemo! both of you! :applause:
Yeah, I'm a dork when I'm drunk. :slap:
gght
Has thanked: 47 times
Post by gght »
[smilie=wine.gif] John Barleycorn's revenge!! :lol:
Damon Jonesta
are you serious? Did you get your beard all messy.
Any way, C15 is missing from your PCB.
And so is C16... not on the board at all... Did ebay sell me a defective copy? :twisted:
I only saw 2-3 differences. Not exactly "completely".
seriously check your lug numbering. It's all backwards.
Thanks for the schemo. You are an example for us all :horsey:
Damon Jonesta
NVM about the c15, c16. Jut saw your post.
You should use my schemo. It looks better :D
dap9
Post by dap9 »
Drinkin' on a Wednesday... I knew there was a reason beyond pedals I love this guy! Thanks for the schemo too. So what are ya drinkin'? I've cut back lately and I've really been craving Guiness and other fine stouts. Wolavers Cream Stout... yuuummmm [smilie=rlp_smilie_242.gif]
Whoismarykelly
Post by Whoismarykelly »
Damon Jonesta wrote:NVM about the c15, c16. Jut saw your post.
Have you met yourself? Seriously the guy gives you his official schematic after saying you have errors on your tracing attempt and you still talk shit.
