d) create your own layout ...
Arsenio Novo - TubeSound Overdrive [documentation]
- frank.clarke
I remember the original posting, but I wasn't good at building stuff then. Nice soundclip, I should try it out.
- modman
- a d m i n
- Has thanked: 4287 times
- Been thanked: 2008 times
PZ, wow both at the clips and the reworking of the circuit.
Incredible stuff. We could give this one its own place in the projects folder (with your name on it) once we rip up a layout. If you feel like sharing it out wide, that is... let me know
thanks for taking this one to your breadboard
- pz
Ok! Just designed the pcb, quite compact and busy, but fits into the 1590B box. Requires 1/8W standing resistors, caps: 5mm raster.modman wrote:PZ, wow both at the clips and the reworking of the circuit.
I'll post the pdf file when i finish labelling the components.
The 3 band tone stack with trimpots could be used with normal pots also, then the Tone knob can be labelled just Presence.
@sosodef:
With the ~200k input impedance i didn't like the sound. The pickup loading was too high, the sound was a little bit like fixed wah effect due to shifting of the pickups resonant peak. With buffer the sound is more open and the circuit reponds better to picking techniues. That's my opinion...
This sounds really good!pz wrote:thanks
here's another sound sample. This time only one guitar. I tried to play some different techniques to show how does this circuit respond to picking and what is the gain range. Again - PX4d used as speaker sim. with a touch of reverb.
sound sample 2 1.8MB
I tried cascading two of such circuits, but the sound was to muddy, to much gain and compression, even when i put the voltage divider between the stages to take the signal a little bit down. With only one stage this od sounds great, probably would be good as booster too.
i just build one TubeSound OD = it's really great !!!!!
I used a 10uF Cap instead of the 22uF Cap = C2
I only had some big 22uF (perhaps replace it or make it switchable = another one 10uF parallel)
Think the Cap at this point makes the distortion more thin, or thick..
I detected such reaction by playing around with the Cap in a FuzzFace Circuit (usualy a 22uF - i replaced it by several other.. a 4,7uF takes the typical FuzzFace Sound away and gives a more Distortion like Tone)
bye
Solderboy
bye
Solderboy
- MoreCowbell
I have vero and perf layouts for it from YEARS ago...i just have to find 'em !modman wrote:PZ, wow both at the clips and the reworking of the circuit.
- MoreCowbell
- gnognofasciani
I've built one and tweaked a little, but it didn't sound that great to me...
Hi,gnognofasciani wrote:I've built one and tweaked a little, but it didn't sound that great to me...
as i build it i had problems with it !!...
unfortunately my 10K Resistors used up and i combinated an 8k2 with a 10K Trim at the junktion between Ground and the "bottom" of the two Transistors
another 10KTrim from 9v+ to bring it to 4.5 Volts after it.
And than i used the 20K in association with the 10KTrim to ground.
there is only a little zone, where it really sounds good (You hear it, when you connect it, hit the Guitarstrings and listen to the Sound whyle carefuly adjust the trim...
perhaps You try out a socket and use different Resistorvalues.
or do You not like the Sound overall?
its a Distortion Sound.... but works great with Guitarvolume !!!
i love it !!!
bye
Solderboy
- gnognofasciani
It worked but not the way I expected
ah.. ok...gnognofasciani wrote:It worked but not the way I expected
its not sooo versatile - no Gaincontrol, no Tone Control, but at the end.. for me.. it makes a quite good Distortionsound... for playing around ok...
Did You try the Highway89 yet?.. thats an Overdrive Circuit, that sounds more smooth, not so edgy, but can work at higher Gain ....
Greets
Solderboy
i'm very very new to this kinda stuff, but could you use the trimpot as a gain control, if you were to wire it as an offboard pot?solderboy wrote:gnognofasciani wrote: its not sooo versatile - no Gaincontrol, no Tone Control, but at the end.. for me.. it makes a quite good Distortionsound... for playing around ok...
i could be entirely wrong about this... can anyone explain how altering the trim pot changes the tone in terms of electronics? is it like transistor biasing or something?
any input welcome, just trying to get a better understanding of how it all works...
- allesz
I just breadborded it two days ago (the simple, original, and unbuffered version, I just used a 10 K trimmer and two complementary bc type transistors (hFe about 250).
I must agree that the circuit is not very flexible; I was wondering about setting the trimmer (by ear), but it was an easy task because it really sounded good in one small fraction of the trimmer travel.
I have to say that the sound is remarkably good: it drives the signal in a different (and more musical) way instead of the usual diode clippers; the sound feels natural, dinamic, shiny and airy;
the gain is not too much but I think that if you use it with a tube amp you can get great sound out of it;
try it, you may discover you just need a one knob thing like this to be happy.
- allesz
Another update, I was experimentig some more on this circuit to tweack it a little to my taste.
I pulled out one of the transistor (the pnp) and the sound remained the same.
I don't understand what happened, I rebuild it some times with the same results, maybe I did something wrong.....
Anyway I am working on the idea as a plain simple booster (with just one tranny), the sound is good. Still I am scratching my head....
Hi all
Following some pretty convicing opinions from a friend reagrding this project I decided to buil it myself, and since while I was searching for info about on the weeb I came across this post I thought ouf leaving my contribution here.
I build it using a 2n3906/3904 pair and .22uF input 0.1/output caps and here's the result :
Sound sample (nevermind the technique)
https://soundcloud.com/#pedro_cabral/an ... und-sample
I also experimented with a fet buffer at the input but I didn't like it...
It was recorded using the setup in the picture:
A yamaha pac311 loaded with fender noiseless and gibson PUs into a Roland Cube (using the onboard looper), out from the line out to a behringer UB502 mixer and into nuendo 3.
Maybe the used sound chain does not make full justice to the circuit, which has to be the best I've ever came across taking into account the ultra-low parts count...Less is best? I guess...
Further into this subject here's a more "scientific" approach in a friend's blog:
http://www.diale.org/arsenio.html
Regards from Portugal!
Pedro
Pedro
Furthermore, here's my simulation of my interpretation of the circuit (@0.25Vpp, 1kHz)
Funny waveform, seems to fold over on itself, just like described by Arsénio Novo
BTW, has someone managed to find out more about the guy himself?
