Page 2 of 2
Re: Dr. Scientist Reverberator
Posted: 24 Aug 2009, 21:41
by RnFR
soulsonic wrote:Dude, that's totally what I thought. I wonder how many of the guys buying $$$ boutique digital multieffect pedals realize they're actually buying homemade equivalents to $80 semi-pro junk processors. Though, I will also agree that the Dr. Scientist thing does look well done and it's clever to see that crammed into pedal form.
:idea: I had this idea a few months back about designing a sort of "wrapper" pedal that would be an adapter that turns the FMR Really Nice Compressor into a compressor pedal for guitar (because it's just about the best compressor on the planet under $2K!). It would be easy to make a universal wrapper that you could use with any number of different small size processors, like the Alesis Pico and Nano series.... though, I would probably cry if I ever saw someone using a NanoCompressor with it because those things are garbage and the idea is you're supposed to use the RNC!
yes, the RNC will absolutely KILL any garbage pedal comp out there. and you can find them for less than most comp pedals as well. just use a looper and stick it off to the side of your board- that would be a simple solution.
