https://www.diystompboxes.com/smfforum/ ... ic=75200.0
This is what I did:
-replace the three JRC022D with RC4559P
(OPA 2134, OPA2132 or OPA2604 should work as well and maybe even sound better, but the 4559 is a good and cheap choice here - don´t use the ne5532 here, because it has a very different input stage -
it´s most important to replace the NJM2068 with a high quality, low noise chip, see below...)
-replace capacitors:
C18,C25, C29, C30 : 0.047 µF
C21, C22, C32 : 1 µF
C13 : 0.1 µF
(use stacked metal film caps (MKT) for all positions!!! Panasonic ECQ-V series sounds very good here)
-Replace NJM2068 at position IC3 with a OPA2134 or 2132 (use a DIP-SIL-Adapter or built an adapter using perfboard). (Look at the photo below)
DIP-SIL-adapter:
http://www.musikding.de/product_info.ph ... --SIL.html (you can buy them from Monte Allums, I guess)
These mods only work with the new version of the GE-7, which looks like this:
http://www.monteallums.com/images/GE7_New.jpg
My pedal with diy DIP-SIL adapter:
