boris
SAD1024-Reverb/modulation-Yugoslavia
- borislavgajic
- Opamp Operator
- Has thanked: 131 times
- Been thanked: 277 times
- borislavgajic
- Opamp Operator
- Dirk_Hendrik
- borislavgajic
- Opamp Operator
no, I did not try to build one, but it looks interesting..........
....I do not know about those resistors....
'...if I am not wrong, r8 and T1 are virtual ground similar to IC1b network(R20,R21)....
G and H are stereo inputs,
P1 ...regeneration
P2...depth
P3....speed(of modulation lfo)
P4....intensity
P5.....delay time
E and F are outputs........
I would like to make one, but do not have any sad1024-s around
rest of it is easy.......that is why I am interested inhow to conwert it to MN3007 BBD
P1 ...regeneration
P2...depth
P4....intensity
P5.....delay time
- Dirk_Hendrik
Correction, I meant C8.
Conversion to MN3207 is simpler.
- himister
I haven't seen this "SAM" publications since 198x.borislavgajic wrote: I would like to make one, but do not have any sad1024-s aroundrest of it is easy.......that is why I am interested inhow to conwert it to MN3007 BBD
Bro, if you do any conversions to MN3007 I hope to see it here soon!
Pozdrav zemljak!!!!
- borislavgajic
- Opamp Operator
so please mr Dirk could you post some drawings how toDirk_Hendrik wrote:Correction, I meant C8.
so this can be my next build (right after English Muffin).......thanks,and please do not post more pics of your pedals...(I am still depressed
boris
p.s.
https://www.diystompboxes.com/smfforum/ ... ic=72329.0
is this good?
- Dirk_Hendrik
why drawings (I'm a lazy fck
), compare datasheets. The SAD1024 and MN3207 are both negative ground chips, the 3007 is not.
Then,
- Bring down the supply voltage in the BBD to 9 volts
- cut out the 2nd section of the SAD. The 3207 is 1024 steps already, the SAD is a double 512 steps.
- make the vgg supply by adding a diode (0.7 volts drop) in series to the 9 volts supply
- Use that 9 volts supply for IC5 too (so the clock pp voltage is 9 volts too)
So now you draw up a schematic, mail it to me and I'll make corrections (if needed)
Then,
- borislavgajic
- Opamp Operator
thank you Dirk!........I'll do my best .......Dirk_Hendrik wrote:why drawings (I'm a lazy fck), compare datasheets. The SAD1024 and MN3207 are both negative ground chips, the 3007 is not.
Then,
