A handy "tip" for drilling your stompbox enclosure
Frequently asked questions about tools and instruments used in stompbox development.
MoreCowbell
Been thanked: 15 times
Post by MoreCowbell »
Sometimes I either order a powdercoated enclosure or paint an enclosure and need to drill it afterwards. This can present a problem because the jaws of the clamp can mar / mess up the finish, and that's not good. Over the years I've done various things to protect the finish, but the solution I finally ended up with has worked out quite well....
I want to the local craft store (Hobby Lobby, Michaels, etc) and got some sticky-backed sheet foam. Its about $0.80 a sheet, and one sheet will last a long, long time. I cut strips from the sheet that match the size of the clamps "jaws", and after cleaning the jaws surface thoroughly, stick the foam to each surface. To ensure that the foam is adhered well, I just crank the clamp closed to put even pressure on both sheets of foam. Now the only thing that touches the stompbox' surface is the foam, so I have to worry a LOT less about marring the finish. After a while when the foam starts wearing out, just peel it off and attach another couple strips. Alternately, weatherstripping should work, but I prefer the foam as its thin and that makes it easy to secure the enclosure properly.
markm
Post by markm »
Great tip MC....many thanks!! :D
BEMUSofNrthAmrca
Post by BEMUSofNrthAmrca »
I like to simply drape an old soft pillow case onto the vice I am using to hold the pedal enclosure.
Duckman
Has thanked: 320 times
Post by Duckman »
Old T-shirt here :lol:
Lucifer
my favorite amplifier: Vyse BBQ Blue
Has thanked: 89 times
Been thanked: 72 times
Post by Lucifer »
I have a different method.
A while back, I purchased some sheets of Tufnol (aka Bakelite) of various thicknesses. It's useful stuff for making jigs and gizmos.
First I cut a backing plate from 10mm thick sheet, about 10mm larger all round than the stompbox (I tend to stick with one size of box where I can, so I only need the one backing plate).
Placing the box lid in the middle of the plate, I then marked the positions of the fixing holes, and drilled them large enough to clear the lid fixing screws. On the back of the plate, I counter-bored to allow the screw heads to sit below the surface, so the plate wouldn't rock when the box is being drilled.
Additionally, I mounted a thicker block of Tufnol onto one of the short ends of the plate, in such a way that, with the plate 'on its back', the block was flush with the bottom edge.
All this could have been done in wood, I suppose, but the Tufnol will keep its shape and last a lot longer.
That's the hard part done - and it only ever needs doing once. Now to drill the box - having already marked out and punched where the holes are to go.
I mount my box, without its lid, onto the backing plate using the lid screws to secure the box to the plate. The assembly can then be held, by hand (as I use a pillar drill), and the top face of the box drilled. If I were using a hand-held drill, however, I would hold the backing plate in a bench vice. It is thick enough not to buckle when the vice is tightened.
The extra 10mm width of the backing plate (ie, 10mm larger all round than my box) means that the assembly can be turned on its side, so the jack holes can be drilled without the lower side of the box getting scratched by swarfe.
Finally, the assembly can then be stood on end (using the end block) so the hole for the power connector can be drilled in the top end of the box. Et voila.
The time invested in making the mounting jig was well invested and, like I said, only needed doing once. My boxes can now be drilled without scratches, and without any risk of vice jaw marks. Seemples !
Dr Tony Balls
Been thanked: 170 times
Post by Dr Tony Balls »
Clamp? :scratch:
Has thanked: 98 times
Been thanked: 274 times
Post by DrNomis »
I tend to leave the finishing of my stompbox enclosures till after I've drilled the holes, since I use unpainted diecast aluminium boxes for my stompbox enclosures..... :thumbsup
Everyone's got their own method of tackling this particular task, one that they find works for them..... :thumbsup
asatbluesboy
Has thanked: 38 times
Post by asatbluesboy »
Let's talk about Leather: LEATHERRRRRR!
...collectors together and emitter to base? You're such a darling...
ton.
