Paul Cochrane - Fat Bastard [documentation]
- sadrew
i don't think it's a problem with the circuit, i double checked everything and it's all ok.
I will try 2N5457, so i can crank more the gain without having much distortion.
thanks modman for the quick reply.
- sevinisthenumber
Any tips/advice on adding some clipping diodes int this for a smooth-ish overdrive tone??
C.S. Lewis
C.S. Lewis
madbean
I think adding another mu-amp stage would be better in this case.sevinisthenumber wrote:Any tips/advice on adding some clipping diodes int this for a smooth-ish overdrive tone??
madbean
Perhaps something like this.
The T1 trimpot could be a 'saturation' control to tailor the amount of overdrive. C3 and C6 might need to be reduced to prevent it from getting to woofy: maybe 470n or 220n. Also, changing the trannys to J201 might give you some more OD.
- mxrmxr
- Degoop Doctor
What is the purpose of c3 and c6 in these mu-amp circuits ?madbean wrote:Perhaps something like this. The T1 trimpot could be a 'saturation' control to tailor the amount of overdrive. C3 and C6 might need to be reduced to prevent it from getting to woofy: maybe 470n or 220n. Also, changing the trannys to J201 might give you some more OD.
- new_anuzzerone
I´ve built it this weekend! AWESOME!
I took the schematic from aron nelsons site (markMs gallery), put the described j201´s in it....awesome!
I used it in front of my Brunetti maranello Amp, clean channel is pretty useless with this, only small amount of gain added. Then I tried the Lead channel and it was way better than any F***drive, TS or whatever! It added just the right amount of gain / drive to make the amp sounding sweeter than ever before. Added a 4x12 to it and I dissected my MrBoogey, which I couldn´t get to work. Great!
THX again to this great board and especially paulc, for showing me, that you don´t need 200 parts, to make some great noise
- Duckman
- Opamp Operator
I started foolin'round with the GGG schem recently and the "search" function lead me to this thread, so following Mr. Cochrane advises (improved input impedance and add output buffer) and taking values from other circuits, I drawn the schem below, but I'm not really sure about the values, so any help will be nice. Added parts are circled
- BOOSTER FAT BUFFER MODc.bmp (866.31 KiB) Viewed 2687 times
- Hides-His-Eyes
C1 is too small, the 10k on the first FET (and maybe the others) might be better off as trimmers (try 100k)
- sinner
- Has thanked: 1031 times
- Been thanked: 907 times
Some of my layouts has almost 200 views and was added 3 days ago, just a single person pressed thanks buttonDuckman wrote:"Viewed 40 times"...?? and no single opinion??
- sinner
Duckman wrote:But... I don't want to be "thanked"just a little help with some values
"There's a jungle out there"
If I'll be able to find it, I'll PM you something tomorrow. It's gone from my HD, but I should have it @ my webmail
- Duckman
- Opamp Operator
Big thanks!Hides-His-Eyes wrote:C1 is too small, the 10k on the first FET (and maybe the others) might be better off as trimmers (try 100k)
I take the 10p cap from the AMZ mini booster input, but 10k resistors are original from the Fat Boostered.
Would you mind to explain me a little more about the advantage of using trimmers and what may I look for?
Thanks again!!
- Hides-His-Eyes
Trimmers are for biasing the FETs to get as much clean as possible.Duckman wrote:Big thanks!Hides-His-Eyes wrote:C1 is too small, the 10k on the first FET (and maybe the others) might be better off as trimmers (try 100k)
Thanks again!!
10k + 10p in that arrangement is a Low Pass Filter. Wikipedia that and see what it's doing
- Duckman
- Opamp Operator
I know what it's doing, but I missed the AMZ Mini Booster uses 1k resistor for biasingHides-His-Eyes wrote:Wikipedia that and see what it's doing
Any way, and sorry for my noobness, the R-C filter still actuates with a FET in between? When I make calculations for the AMZ MB ( 1k/.00001uF) freq values are ridiculous.
Now, thinking about the low pass between R2/C1, C1 @ 220p will give me 10644 Hz wich seems more apropriate, don't you think?
- RnFR
you added an extra gain stage on the end. I would try simply adding another FET dc coupled onto the output of the mu amp with the drain going to 9v and a 10k resistor from source to ground. then put your output cap and treble cut control. check out geofex's mu amp article or some of the victor kempf stuff. as far as the input, I'll have to read up on what paul was talking about, because a jfet input buffer already has a rather high input z.
ok, make q2 a FET. lower the source resistor on q1 for more gain. move the 1m bias resistor to the gate of q1, and use a trim for r3. upping the value of that 10p might be a good idea as well. that should do it.
- Duckman
- Opamp Operator
Thanks, RnFR, a lot of help! Also added "noisless biasing" according with R.G. Keen Mu-amp article.
Ok, guys ... what you think?
- BOOSTER FAT BUFFER MOD v1.1.bmp (866.31 KiB) Viewed 2610 times
- Nikifena
I think that this is better
I put smaller input resistor, change protection with schottky diodie. Now we loose 0.2-0.3V, but the diode can't blow
Now we have lower output resistance
- BOOSTER FAT BUFFER MOD v1.1.bmp (866.31 KiB) Viewed 2540 times
