Voltage Doubler using NE555 timer
cacophony
Post by cacophony »
Hi guys! I'm just wondering if this schematic I made through EAGLE CAD is the same as the one posted at http://www.elecfree.com/electronic/volt ... th-ic-555/ Image
I find the schematic posted at the said website unclear enough.
Thanks.
Also have a look here:
viewtopic.php?f=13&t=80&
JiM
Proco Rat
Hot Harmonics
Crackle Not OK
Has thanked: 69 times
Been thanked: 65 times
Post by JiM »
There shall be no connection between C4 and the output voltage ! You're shorting it to Vcc, defeating the purpose of the circuit.
I agree it's not easy to see in the original schematic that there is NO dot where these wires cross ...
earthtonesaudio
Been thanked: 75 times
Post by earthtonesaudio »
Ah! Good call, JiM. I glanced here earlier but failed to spot that! I agree, C4 should connect to the main supply only, not to the boosted voltage. It would be even better to show it directly across pins 1 and 8 of the 555, because it should be as close as possible to that IC in the board layout.
One more thing, it wouldn't hurt to add the typical .01u cap from pin 5 (CV) to ground.
cacophony
Post by cacophony »
earthtonesaudio wrote:Ah! Good call, JiM. I glanced here earlier but failed to spot that! I agree, C4 should connect to the main supply only, not to the boosted voltage. It would be even better to show it directly across pins 1 and 8 of the 555, because it should be as close as possible to that IC in the board layout.
what does the 0.01 uf cap do to the timer?
earthtonesaudio
Reduces noise/false triggering when using a bipolar 555. It may not be necessary, but it wouldn't hurt anything to include it.
