Here's some guts shots of the Chuck Collins repro which is supposed to be true to the original design:-
There's a rebuttal to that claim on the Chuck Collins site, and it's generally regarded that the Barge version doesn't sound or behave like the original.soulsonic wrote:Anyone else here notice the story on the Barge site about the "true" HP-1 using two identical NPN transistors instead of the NPN/PNP mixed pair that you see in every other schematic?
Interesting.
Anyone here ever build one with two identical NPNs?
This is ridiculous - you know, all someone would have to do is carefully remove the transistors from an original and then test them with an Atlas DCA55 semiconductor analyser and we'd know exactly what sort of transistors are in there! You don't even need an Atlas tester, anyone with a brain could do a simple battery of tests to determine the polarity of the things and whether they have any leakage (a sure sign of a germanium device).Greg_G wrote:There's a rebuttal to that claim on the Chuck Collins site, and it's generally regarded that the Barge version doesn't sound or behave like the original.soulsonic wrote:Anyone else here notice the story on the Barge site about the "true" HP-1 using two identical NPN transistors instead of the NPN/PNP mixed pair that you see in every other schematic?
Interesting.
I've already posted gut shots of the Chuck Collins pedal.soulsonic wrote:This is ridiculous - you know, all someone would have to do is carefully remove the transistors from an original and then test them with an Atlas DCA55 semiconductor analyser and we'd know exactly what sort of transistors are in there! You don't even need an Atlas tester, anyone with a brain could do a simple battery of tests to determine the polarity of the things and whether they have any leakage (a sure sign of a germanium device).Greg_G wrote: There's a rebuttal to that claim on the Chuck Collins site, and it's generally regarded that the Barge version doesn't sound or behave like the original.
And if Bruce has indeed done this... why isn't anyone sharing the info about the correct transistor part #s?
Does anyone here have one of Bruce Collins' remakes that we might see the guts of, or perhaps at least share the model numbers of the transistors used?
I honestly don't care which of the two parties is correct in this issue - or even if either of them are correct - I just want to lay the mystery to rest. That's what this forum is all about: studying unique circuits and uncovering the truths behind the mysteries which enshroud them.
True soulsonic.soulsonic wrote:Okay, I see now. Thanks for sharing that - I must have not been paying attention, because now I remember seeing it.
Those gutshots should be presented together with a schematic so people will correctly connect the two, instead of getting stuck on false notions like I did.
This is a good example of how the disorganized aspect of the DIY community has led to confusion over the years.
Thanks for sharing, and I'm sorry I didn't pay closer attention.
