Identifiying Diodes
Frequent question abouts LED and other types of diodes.
trad3mark
my favorite amplifier: Vox Valvetronix Series
Completed builds: Super Hard On
Fuzz Factory
Aenima/Torn's Peaker (2 in 1 box with toggle switch)
Valvecaster Deluxe (Boost before VC)
Proco Rat (Mod to power jack, and input cap changed)
87% PillowStone
87% GlassJaw
Post by trad3mark »
Right, so i'm about to embark on the mother of all salvage fuzz projects... A green russian BMP
"In Russia, pedal salvages you..."
Only thing i have left to find is the diodes. I have 1 x 1N4148, but i need 4. I have 14 mystery diodes sitting here. Is there any way i can identify them, or, if it doesn't really matter what diodes i use, could i use LED's?
Greg
Completed builds: LOTS..
Has thanked: 64 times
Been thanked: 163 times
Post by Greg »
If you have conventional silicon diodes.. they should be fairly similar.. check the Vf if you can with a multimeter.
The LEDs will work but will be quite different to a 1N4148 or similar.
trad3mark
Fuzz Factory
87% PillowStone
87% GlassJaw
Post by trad3mark »
ah! it looks like my DMM will do the trick! so when i switched it to diode mode, and connected the probes to the diode (the one 1N4148 i have(, my reading came up 796. I assume then if i can find 3 others that read 796, or close enough to it (a second one just read 795 and an LED read off the dmm, and turned on lol!) that they'll work just fine??
Greg
Post by Greg »
trad3mark wrote:ah! it looks like my DMM will do the trick! so when i switched it to diode mode, and connected the probes to the diode (the one 1N4148 i have(, my reading came up 796. I assume then if i can find 3 others that read 796, or close enough to it (a second one just read 795 and an LED read off the dmm, and turned on lol!) that they'll work just fine??
:thumbsup
That's the reading in mV.
If they're pretty close they'll work fine.
trad3mark
Fuzz Factory
87% PillowStone
87% GlassJaw
Post by trad3mark »
great! thanks!
i only had 5 hole deep stripboard left, so......
my vero:
http://i31.tinypic.com/2mzdt9d.gif
