Alternative Value Difficulties
trad3mark
my favorite amplifier: Vox Valvetronix Series
Completed builds: Super Hard On
Fuzz Factory
Aenima/Torn's Peaker (2 in 1 box with toggle switch)
Valvecaster Deluxe (Boost before VC)
Proco Rat (Mod to power jack, and input cap changed)
87% PillowStone
87% GlassJaw
Post by trad3mark »
Hey all,
Just a quick question on using alternative values for things. We've all had those builds where we need to use substitute values. I've done ones where the substitutes have been really close. Things like 12k resistors replaced with 15k resistors, or 20nF caps replaced with 22nF caps. As i'm sure a lot of you will agree, a lot of the time, if the values are close enough, it won't really make much of a difference a lot of the time.
My question is, what if almost the entire board were substitutes? Obviously, the sound will be noticibly different. This may be tone, volume, fuzz amount etc etc, the list is endless. But, will it always still work provided the values are pretty close?
I'm just about to debug a Green Russian BMP build, but there's a lot of alternative values. Most are REALLY close, as described above. But there's a few i'm not sure about. The furthest one out in terms of resistors is a 470k replaced with a 600k, or a 2.2m replaced with a 3m. It should work really, right?
I'm so confused.... :scratch:
willc1968
my favorite amplifier: Kustom K 200 A-4 in red
Completed builds: kay fuzz, clark fuzz, ea tremelo, green ringer, tremelus lune, a few big muffs, fuzz face and factory, sft, woolly mamoth, a bunch of tonebenders and many more that need to be boxed
Has thanked: 20 times
Post by willc1968 »
when i want or need to have resistor values dead nuts on i just get out the multimeter and try to find 2 resistors or sometimes 3 that will work in series. finding a parallel equivilent is also an option and is sometimes easier and neater because using 2 components where only 1 is allowed for can get ugly at times. hope this helps. will
earthtonesaudio
Been thanked: 75 times
Post by earthtonesaudio »
There are places where it matters more, like transistor biasing. If you don't have the proper values, it may be beneficial to scale the other values to match what you do have. For example if a transistor's base is biased by 10k and 100k resistors, you could substitute 47k and 470k, and end up reasonably close to the original bias point. Of course then the frequency response is changed, but cap tolerance is generally much worse than resistor tolerance so that part is a bit of a roll of the dice anyway.
JiM
Proco Rat
Hot Harmonics
Crackle Not OK
Has thanked: 69 times
Been thanked: 65 times
Post by JiM »
In DIY fashion you can take some time to test parts for actual value within tolerance.
For example, a 10k 10% resistor will more efficiently replace a 12k if it's close to the max value (i.e. 11k) rather than the min.
[Slightly off topic : i remind an experienced engineer saying that back in the day, a 10% resistor was always more than 5% off the specified value, as these were factory-sorted ... nowdays i'll expect a nice gaussian curve.]
Anyway, for a Big Muff it doesn't matter much, as there were quite a lot of variation in the official schematic along the years ...
