How do you transfer a schematic to bread board?
Posted: 07 May 2009, 11:05
by PedalPlayer
I'm kind of new at this and I was wondering, how to you guys look at the schematic and then come up with the layout? I've always had trouble following the schematic, and I can't see how you would be able to transfer the two. Any help would be great. Thanks.
Re: How To You Transfer a Circuit To a Breadboard?
Posted: 07 May 2009, 11:31
by IvIark
Beavis Audio have a great guide From Schematic to Reality, check it out.
by Scruffie
Here ya go, everything you should need to know,
http://www.beavisaudio.com/techpages/Sc ... ToReality/
Posted: 07 May 2009, 20:18
by PedalPlayer
Wow, that's really helpful. The only thing I don't understand is what is the deal with the jumpering? Why are some of the spots on the breadboard jumpered?
Posted: 09 May 2009, 17:01
by cpnyc23
Because of the way breadboards are laid out, you only have so many continuous rows. You need to run a jumper to connect the different strips to other parts of the board. Think of jumpers as traces on a circuit board - they are just conduits for electrons to flow to normally unconnected pathways.
-chris
by cpnyc23
-chris
Posted: 10 May 2009, 16:34
by PedalPlayer
Thanks for the response about the jumpers. That makes sense and that was what I thought they were for, I just wasn't sure.
Posted: 19 May 2009, 01:09
by sgtdrpepper
Thanks for the links i just decided to give effects building a try and there is a wealth of information in these forums.
