DOD - OD-250 (3 different versions)
wader2k
Post by wader2k »
analogguru wrote:
wader2k wrote:
analogguru wrote:
.....but I'd really like to know which ckt is the venerable gray box that draws so much crazy money on ebay.
None of them.....
as you can see here:
https://cgi.ebay.com/ws/eBayISAPI.dll?V ... :IT&ih=017
it´s an Mxr Distortion+ circuit housed in a Dod-case.
The variations came later.
this I knew......but it doesn't help.......
let me rephrase....what value for R4 would I most likely find if I opened up this?
https://cgi.ebay.com/ws/eBayISAPI.dll?V ... :IT&ih=007
8^)
Sorry that I don´t look at others people schematics - I draw my own.
I like to draw my own also.....I do have a BSEET and 25 yrs experience in electronics.......but guitar pedals is a new hobby to me....
Therefore I can´t say what is R4 or R2.
If you opened up this specific unit you must have bought it before :roll: .
But if I had the money to buy it, I wouldn't need to build it would I? After all, this is the "haven for free exchange of diy guitar electronics" No? :)
But there is already a gutshot of the opened unit. From this gutshot I can tell you that it is most likely a 1979 unit, at least from the last weeks of 1978. Only during this period they used the 741´s from RCA in the grey 250.
Now we're getting somewhere.....
Anyway, the feedback resistor was in all units from 1976 to 1979: 1M.
Yup, this I have established
The bias resistor was in 1976 470k, in 77/early 78 510k, the rest of 78 and 79 it was again 470k. With a freeware graphic programm maybe you will be able to recognize the yellow and violet ring in the gutshot.
Thank you, so much!.....and btw.. I'm semi colorblind so I don't trust myself to read colorcodes correctly without a dmm to check.......I wonder why markm's layout and others I have seen indicate 1M for the bias resistor as to my original question? No matter 470k it is.....
BTW, do you have a 741 from RCA ? I think this will have more influence on the sound than the stupid bias resistor - especially when the input coupling cap has a tolerance of 20%, like in this case.
Why yes I do believe I do!......and messing around with the .047uf gain cap will have even greater effect..
Thank you for taking the time to help me out here AG...I do appreciate it!
8^)
Wade
lonewolf
Post by lonewolf »
Hey sorry to bust in.. can anyone tell me how I can accurately date my yellow DOD OD-250? I know it's not a reissue..that's about it.. Thanks!!
rockintothebone
Post by rockintothebone »
My first attempt at making a vero layout for the DOD 250 grey
Let me know if there are any errors in this layout
cheers !
rockintothebone
roseblood11
Has thanked: 359 times
Been thanked: 312 times
Post by roseblood11 »
It would be easier to check it if you would add the parts values...
rockintothebone
Okay im working on it..
apparently the layout is wrong...
ill repost one again in a few ...just going through it again ...
how do i delete that post ? its very misleading...
rockintothebone
hope this ones not messed up ..
Lonkero
my favorite amplifier: Tech 21 trademark 10
Post by Lonkero »
Built the 77 grey version on solderless bredboard. I also have built the other gray version which I prefer.
The 77 gray version has a nasal tone on it. This is probably because the 2,2 n cap to ground after input and also 1N4001 clipper diodes.
Tone is a bit darker than the other gray version. Despite the kind of annoying nasal tone I was suprised how amazingly well it picked all the pinch harmonics. Maybe one of the best pedals I've tried for just
messing around with screaming pinch harmonics (weird for pedal like this, huh? :hmmm: ). It feels a bit same like you'd have a wah pedal on middle position. Overall, the 77 version is definetely a good pedal to build for certain solos were you need a tone that's not too bright yet still cuts through great.
LooseCannon
Post by LooseCannon »
Hey guys,
I've seen different layouts with a different order of the .047uf cap and 1M resistor, and the 4.7uf cap and the 10k resistor, on some of them the cap is first and on some the resistor is first.
Does it make a difference if the cap is before the resistor and vice versa?
LooseCannon
Correction- the .047uf cap and 4.7k resistor. How do you edit posts? :)
No it doesn't
You can see similar debates in Big Muff or/and Tube Screamer discussions
LooseCannon
Thanks sinner!
