-Swap one of the red clipping LEDs for Ge, one for Si (small signal types).
-Add 100k in parallel with R13
-Add 1k in parallel with R20
-Add 1M in parallel with R35
-Add 22k in parallel with R26
-Short R24
-Add 47n cap in parallel with C23
There are 2 reasons for doing all those things in parallel: it's obvious what and where the mods are, and easy to revert back to stock if desired (just snip out the added parts with a pair of side cuts).
Before I did these mods, it was easy to get a bad sound, impossible to get any good sounds from it (my subjective opinion of course). With the mods, it's a lot more flexible. It does several new awful sounds, plus some good ones.
Note that the R13 mod affects the bypass tone as well (increases tone suck). Perform this mod at your own risk.
