EHX - Q-Tron [schematic]
- soulsonic
- RnFR
"special thanks to the IP Troll."
- modman
- a d m i n
- Has thanked: 4287 times
- Been thanked: 2008 times
Great!
- noelgrassy
- my favorite amplifier: MOTS Magnatone & Trainwreck
- Completed builds: Tonebender Mk II w/ 3 OC75's, Burns BuzzAround w/NKT 275,Rangemaster w/ OC44, Fuzz Face w/ SKS363's, CJOD, Harmonic Percolator w/2N404A & 2N3635(vintage correct box,sliding pots, 1%glass resistors),Stack-O-Dimes & Whipple Wahs,
- Has thanked: 11 times
- Been thanked: 3 times
Thanks man!
noticed the mini/normal qtron is posted but the micro seems to have a slightly different construction (has a different opamp i believe) it might be an equivelant part but the interesting thing i found is that the IC name (and most of the other part names/values) are printed on the board.
the blue board makes it hard to capture the traces, if photoshop doesnt help il take some new snaps in better lighting.
gallery > http://yfrog.com/0fdscf0237oefjx
https://img15.imageshack.us/img15/3903/dscf0237oef.jpg
https://img10.imageshack.us/img10/6977/dscf0238mmv.jpg
https://img14.imageshack.us/img14/9600/dscf0239.jpg
https://img15.imageshack.us/img15/9656/dscf0241w.jpg
https://img5.imageshack.us/img5/6003/dscf0242y.jpg
https://img7.imageshack.us/img7/3379/dscf0243m.jpg
- toneman
- my favorite amplifier: anything that works
- Completed builds: meatolation, wobolation, ringolation clones, PAiA synths/modulars, dipthonizer clone, MOTM modules, pedal mods and repairs
- Has thanked: 178 times
- Been thanked: 45 times
right on, right on , right on!
Tone-to-the-Bone
- Andy2No
I'd be interested in seeing those pictures, but unfortunately, all the image links have expired.Samba pa ti wrote:noticed the mini/normal qtron is posted but the micro seems to have a slightly different construction (has a different opamp i believe) it might be an equivelant part but the interesting thing i found is that the IC name (and most of the other part names/values) are printed on the board.
gallery >
Does anyone still have them?
Is the Micro Q-Tron similar enough for the Q-Tron schematic to be relevant?
- Blitz Krieg
there are essentially two differences. the mini runs off +/-4.5V. and it has a zener in the envelope rectifier section thingy.Andy2No wrote: Is the Micro Q-Tron similar enough for the Q-Tron schematic to be relevant?
hi there guys
i've bought this "not working" Qtron for 30 euros.
i thought i should post those pics cause i didn't found any gut shots of this one anywhere.
i've found some differences compered to that schem, but got lost.
seems like the one i have on hands, mixes the sides of the ic's in some way i can't understand.
i bought it just for the parts but...
i would love to give it a try and fix it.
...and if someone more experienced is willing to help i would be very happy.
HERE WE GO..
i've re-wired footswitch cause it was about to fall apart and i'm about to change gain pot too.
it passes the signal when it's on, but there is no filter there.
voltages look good at all ics pins
all pots seem to do "something" but as i said there is no effect.
SO...
the strange thing is that when i bring my hand near the pads where there is a place for that dpdt switch under the sweep switch, it acts like a theremin and effect comes alive somehow. as i move my hand on those pads, there is wah wah effect that changes according to my moves.
the same thing happens when i approach the back of that sweep-responce-drive switch.
are my optos dead or something?
i've tried to trace the signal but as i said i got lost cause i think that this board uses the ics's sides in a different way than the schem posted.
thanks for any help
HERE WE GO..
SO...
thanks for any help
- Andy2No
Did you get it working, ksenanekro?
I can see three electrolytic capacitors on the underside of your board. I'd replace all of those - same capacity, and at least the same voltage rating, preferably higher.
When I first read about putting your hand near it and getting an effect, I was thinking of "hand effect" which radios can suffer from - the original theremin was based on that, I guess. Possibly you're just reflecting the light from the LED though?
I'd consider replacing the LED. They can have a fairly short life. Look for dry joints, and resolder them too - with proper 60/40 tin/lead solder, not the crappy new lead free sort.
- howmuch
Is that some version of a Q-Tron?
It looks a lot like a Q-Tron+.
Edit: Sorry, I just noticed that the Q-Tron+ is the "Same design as the original Q-Tron but with extremely useful Effects Loop and an Attack Response Switch".
From those photos, it looks like they share the same PCB, with the Q-Tron having un-populated parts (FX loop and Sweep Up/Down switch).
Hello, im working on fixing a Q Tron like this. Im following the signal and i hace no signal before the rotary switch that controls the boost. Is there a chance that the rotary stop working. Can someone tell me how can i test the 2p2t rotary with a multimeter?
Like this you mean the blue pcb?
Cause it seems to me that its not the one in the schematic in first post.
Blue pcb have 2 separate ldrs while the scheme above have a double one (maybe)?
Can someone confirm this? What was the double-ldr used in the old q tron version?
