WMD Geiger Counter - [gut shots]
- rousejeremy
- SPeter
- rousejeremy
- noelgrassy
- my favorite amplifier: MOTS Magnatone & Trainwreck
- Completed builds: Tonebender Mk II w/ 3 OC75's, Burns BuzzAround w/NKT 275,Rangemaster w/ OC44, Fuzz Face w/ SKS363's, CJOD, Harmonic Percolator w/2N404A & 2N3635(vintage correct box,sliding pots, 1%glass resistors),Stack-O-Dimes & Whipple Wahs,
- Has thanked: 11 times
- Been thanked: 3 times
WMD Devices have built these pedals stout and capable of very crazy sounds.
Oh they're bitchin' alright but the designer has protected his creation with goop. The Obsidian colored
lumps are as hard as Borosilicate (Pyrex). I'll eventually take this thing to task but still haven't fully
explored all the possibilities available in this off-the-chain FX.
I have his 'Fatman' pedal too. An Envelope Filter for any instrument.
Here's the pron:
Excuse the lack of photo skills. I'll re-take them when I get the time.
NG,
Here's the pron:
NG,
- rocklander
- Has thanked: 1404 times
- Been thanked: 227 times
- Contact:
ignoring the goop annoyances, I like the way they've folded back the shielding before putting heat shrink over them, in order to avoid potential shorting of shield to centre.. I'm slapping my forehead (having never seen that before) wondering why I never thought of that myself. I have always cut the shield short and hope no strays get past, but leaving them long and folding back is a great idea
- rousejeremy
I'm really glad someone here has one of these pedals. They are unique in their own way, which I dig.
noelgrassy wrote:WMD Devices have built these pedals stout and capable of very crazy sounds.
NG,
- rousejeremy
Which is why I hope someone can reverse it
iloop wrote:SO COOOOOOOOL
Pure awesomeness. Schematic
- Dirk_Hendrik
1 point off for PCB layout. What was used this time? MS paint?
- devastator
Every minutes of the proguitarshop demo video make me laugh. That pedal looks like a pedal which met a coca-cola
(why buying that pedal ? Buy an analog synth that will do that sound better).
Anyway, that can be interesting to see what's inside .
- soulsonic
where's the computer? those gutshots have me confused. Just looks like a bunch of crap in there.
- RnFR
i thought this thing was digital??
- celadine
PIC/AVRs etc. can come in 8 pin dip packages, like dual op amps. Or it could be that the input signal ramps through addresses in an EPROM containing wavetables.
The following design uses a vco to ramp through addresses, but it gives the general idea:
http://www.digisound80.co.uk/digisound/ ... 21_ETI.pdf
see also the Waveform City:
http://www.wiard.com/modular/waveform_c ... _city.html
- soulsonic
I understand that, Celadine, but why put goop all over it. What a waste!
Since it's all gooped up like that, you can be fairly sure it's copied, at least in part, from another design.
- rousejeremy
Is this true? Do other builders do this to pedals that are just a hot rodded so and so?
soulsonic wrote: Since it's all gooped up like that, you can be fairly sure it's copied, at least in part, from another design.
- culturejam
Some of them do it for this reason, yes.rousejeremy wrote:Is this true? Do other builders do this to pedals that are just a hot rodded so and so?
The Jetter Gain Stage Red is a prime example.
