MXR - Micro Chorus  [schematic]
kdude34567
my favorite amplifier: VHT 2/50/2
ADA MP1
Marshall 1960B cabs
Completed builds: Custom Made Rack Amp & Effects Switcher & Foot Controller
MXR Phase 90: 70s Script mod, '70s Block mod
Restore/Rebuilds: MXR Distortion+, Flanger, Phase 100, Phase 90 MicroChorus, MicroAmp, NoiseGate, Blue EQ10, Mutron Phasor II, ElectroHarmonix PloyFlange, Commande Delay, DOD 250OD, Zeus 8444 Preamp, Thomas Organ CryBaby, Westbury W20 Tube Preamp, Maestro EchoPlex SE1 Sireko
Post by kdude34567 »
I realize this thread is a couple years old, but I've watched these threads on this site for a long time, but it matches my problem description fairly close, so I figured it to be most relevant. It always seems that great dialog, awesome tech info, & good people jump in on these posts to help out & support guys like us who have a ton of old pedals and do all their own tech work, mods, repairs, builds, etc. So my hope is the same will happen with my post :)
Anyway, I've got a 1978 MXR Micro Chorus I've had since 1978 when I bought as a teen rock guitarist, along with my MXR Phase 90 (1977), Phase 100 (1975), Micro Amp (1978), Flanger (1977), 6-band EQ (can't remember what year I picked it up), and Noise Gate (1978). The Chorus broke down years ago when the the SAD512D BBD chip failed. Been on the hunt for a new chip for many years, but alas, they're either totally unavailable, or some scheister is asking $50-$100 for one, and 9X's out of ten, what you receive doesn't work anyway, because either A) the guy's a scheister, or B) in the process of removing and/or packaging, the guy fried the chip.
So I had resigned myself to convert the pedal to the MN3007 version posted elsewhere on this site, a very good post, great info & a lot of details/dialog, that I've been following for years now. If fact, the schematic and other info from that thread were the backbone of support for this latest repair effort for this pedal. Just couldn't bring myself to modify the old girl from the stock circuit w/o hopes of a SAD512D falling out of the sky someday to solve my problem, so I could resurrect the old girl.
So I've went down the path along these lines and ended up with my current problem:
1) I found a source in Hong Kong claiming to be making & selling brand new made SAD512D & bought (3) @ $6 each to see if I could resurrect the chorus. A company called DigChip, who sells a ton of all kinds of ICs & related, claiming ED*GE is the company manufacturing these new SAD512D chips. The problem is these are not real Reticon chips & I have no idea is these guys are making a true quality knock off, or simply a weak facsimile. Has anybody else heard of this or tried these chips? Are they any good? Because I'm not having great results with them, and I need a sanity check to see if its just me & my repair effort failing, or is it these dang chips!
DIgChip.hk SAD512D Product Page: http://www.digchip.hk/stock-SAD512D.html
NOTE: Keep in mind the last time I was under the hood looking at the circuit & components on the pedal was probably 20 years or so ago, I don't remember if other components were bad besides the known bad SAD chip, when I started this new effort. Needless to say, I've been deep under the hood on it now for a couple of days straight, starting at ground zero going through everything, & just cannot get the dang pedal to work completely. It's in a weird 'almost working' state, but not really. That said, I'll break down where I'm at now & why I need some assistance, or at least a sanity check & someone to bounce things off of.
2) I've gone though the entire circuit. I replaced the old failed Reticon SAD512D w/the new DigChip SAD512D, the TL061 & TL062 op-amps w/new ones, as well as all (4) ZTX109 transistors with 2N3904, along with a bunch of caps, mostly in the output section post SAD chip, as well as changed the (2) 10uf Tantalum caps to quality electrolytics. But still can't get the pedal working really. Its basically passing through clean signal with a very slight bit from the effect, that's has a bit of LFO noise and possibly a very very VERY faint chorus, but I don't think so (Its wishful thinking I think)! Its driving me nuts & I've hit a wall...
NOTE: I'm using an old BK o-scope, hand made audio probe, & decent quality DVMMs (Fluke 87 & Protech 506), plus have all the tools of the trade, a nice solder station w/fine tip, hand tools, PCB supplies, solvents, flux, cleaners, compressed air, etc. A fairly decent stash of components, connectors, hardware, etc (except a dang real Reticon SAD512D chip!).
3) Here's the troubleshooting breakdown:
*The clean signal is fine & being passed thru all the way thru to pin 7 (output of U1b) of the TL062, so I know the chip is working, especially U1a, though I have no signal I can see on the scope or hear with the audio probe on pin 6 (input of U1b) of the TL062, yet the clean signal is strong at pin 7, as well as at the output jack, so it must be making it through the resistors/capacitors above U1b on the schematic (R11, R15, C6, & C8), because I don't see any input at pin 6, which would be needed to be able to output on pin 7, whether from the clean signal coming thru R16 (270k) or the effect signal coming thru R17 (240k). Plus I replaced the TL062 w/a new one with same result. So I'm wondering why pin 6 has nothing on it. Clearly the input signal is present on the other side of the 270k resistor, so why nothing on pin 6. Now the SAD512D output is a more convoluted story. I'll get to that in detail in the next bullet point...
*Basically, there appears to be a true summed BBD output, where I can see on the scope, what appears to be a modulated signal riding on top of a bunch of clock pulses, where the odd/even output are summed together, and there's no dropout between clock pulses, but its very weak at only .4-.5V, and appears to die off by the time it reaches the base of Q2. Using the audio probe, I confirmed exactly that. I can hear a weak modulated output w/clock artifacts when probing pins 3 & 4 of the SAD chip, nut don't hear anything coming out of Q2. So what could be killing the signal at pin 6 of the TL062? And what could cause the new SAD512D summed output (pins 3 & 4) to be so weak and at such a low voltage?
I changed most of the caps post SAD chip to eliminate a bad cap taking out the effect signal coming out of the SAD chip, but to no avail. Same result after all those caps were replaced w/new ones. I also tried 2 of the 3 new SAD512D chips from DigChip. Same exact results with both. I haven't replaced the resistors yet post SAD chip, though unless destroyed, burnt, shorted, or opened, resistors aren't usually the culprit in this type of scenario. The pedal is running off of 9VDC battery, so no AC earth ground involved, and I can't find a short anywhere in that part of the circuit. So is there something else I can look for that would cause this, or is my fear confirmed, these DigChip.hk SAD512D chips are just no good, and have a really low quality BBD output w/a very low level. If not the circuit itself cause the issue, could it be something with the clock signal causing this? Which leads me to my next point...
*The TL061 & clock/LFO circuit appear to be working, though the actual clock arriving at pin 1 of the SAD chip looks pretty dirty to me w/a lot of slope & rounding in the square wave. The output on pin 6 of the TL061 however, is very strong and swings from 0V to 9V (Battery V+, battery voltage was actually around 8.3V - 8.6V throughout the effort ), around every 50msec, or about 20Hz, and the square wave is a lot cleaner & has very little slope or rounding of the pulses. The clock signal after going through Q3 & Q4 w/related RC networks, at pin 1 of the SAD chip, is also swinging between 0V & 9V, about every 14usec, or 71KHz.
Frequency wise, that's probably about normal since the clock has to be 3-4 times that of the input signal for the SAD chip do its BBD thing. TR1 & RV1 both seem to be working and behave roughly as expected. RV1 changes the speed of things, which I can hear with the audio probe and see with the scope, and TR1 changes the bias voltage as expected, which I can also hear & see in the weak output of the SAD chip and read with my DVMM. The problem is the bias trimmer never really finds a point (voltage), where the SAD chip kick starts the modulation process into full motion, and the SAD512D weak output never makes it the pedal output. Could it be the clock? I read somewhere that the clock is not supposed to go below 5V, and it definitely is in my case. What could cause that? Also, the clock doesn't look like a clean square wave, its kind of a blend between a saw-tooth and square wave, where the valleys between the pulses drop below 5V.
VOLTAGES (DC) as read by DVMM:
V+ Battery: ~8.3V - 8.6V during testing
Vbias: 3.2V
Vbias range: 2.2V - 4.4V
Vdx: 7.9V
SAD512D
pin 1: 4.2V - 8.2V, 5.4V - 7.2V clock swings (meter cycled between these ranges)
pin 2: 0V
pin 3: .4-.5V
pin 4: .4-.5V
pin 5: 8.3V
pin 6: 1V
pin 7: 0V
pin 8: 8.3V
TL062
pin 1: 3.3V
pin 2: 3.3V
pin 3: 2.9V
pin 4: 0V
pin 5: 3.2V
pin 6: 3.3V
pin 7: 3.3V
pin 8: 8.2V
TL061
pin 1: n/a
pin 2: 2.6V - 8.2V swings
pin 3: 2.2V to 8.2V swings
pin 4: 0V
pin 5: n/a
pin 6: 0V - 8V clock swings
pin 7: 7.9V (Vdx output from R25)
pin 8: NC
Q1
E: 1.2V
B: 1.7V
C: 8.2V
Q2
E: 25-45mV
B: .4-.5V
C: 8.2V
Q3
E: 0V
B: .4V
C: 4-8V clock swings
Q4
E: 0V
B: .4V
TR1
(+): 4V
wiper: 3.2V
(-): 2V
RV1
grey: 2.2V - 5.5V swings
orange: 1.29V - 6.6V swings
So ideas or suggestions on what could be causing these issues?
1) No signal at PIN 6 of the TL62 (0V, flat line on scope)
2) Weak SAD512D output on pins 3 & 4 ( .4-.5V, can barely hear it w/audio probe)
3) Dirty clock signal at pin 1 of SAD512D with alot of slope & rounding, with valleys between pulses below 5V
4) And ultimately, no chorus effect coming, only dry clean signal w/minor clock artifacts coming through.
Are these Hong Kong SAD512D bogus? Or are there things in the circuit that could be the problem?
I have enough components to replace every component in the pedal, except a real Reticon SAD512D, but before I do, I wanted a sanity check on what I'm seeing.
Any help would be greatly appreciated!
Kdude
Lead Guitarist White Lie & Guitar Gods
Musical Instrument/Gear Aficionado, Collector,Trader, Restorer, Repairs
Product Manager/Application Engineer Electronic Security Industry
Techno Geek, Half-Baked Inventor, Wannabe Scientist
Fender3D
Has thanked: 120 times
Been thanked: 150 times
Post by Fender3D »
Pictures on 1st post got lost...
kdude34567
ADA MP1
Marshall 1960B cabs
Thanks for reposting the MXR MC pics Fender3D...
Kdude
Noth
Post by Noth »
I'm debugging an old MRX Micro Chorus (hoping it's not a dead SAD512D), chorus has strictly no effect, signal outputs as clean as input.
When I measure the CLK signal on pin1 of the SAD512D I got the following (see picture).
SAD 512D clock
SAD 512D clock
I'm more a digital king of guy, so for me clocks tend to be square...
Is that a "normal" CLK signal for the SAD512D ?
Noth
Post by Noth »
From what I've read here viewtopic.php?f=10&t=21882 the CLK signal is supposed to be a 17KHz square signal.
I was sampling at 100Hz so ... :)
I did try at 125 k samples/s without much success: still not regular, still not square..
Fender3D
Post by Fender3D »
Noth wrote: Is that a "normal" CLK signal for the SAD512D ?
Your picture does not give any info about frequency...
but definitely that's not a proper clock signal.
Check Q3 and Q4 and their neighbours, especially C19
Noth
Post by Noth »
Thanks for your feedback, I'll take a look at this part of the circuit.
As far as I've seen, it appears the stompbox had a violent shock: several of the ceramic capacitors had impact (they did probably hit the back plate) and I had to replace them.
I still didn't replace C19, it seems a good candidate.. :)
Noth
Post by Noth »
I did check Q3 and Q4, they seem correct: HFe between 300 and 400 (matches the datasheet http://www.farnell.com/datasheets/49571.pdf)
I unsoldered C14, C16 and C19 : they also seems fine, but I will replace them anyway just in case..
I also did check the first clock stage, at the TL061 output: this seems fine, I have a square signal properly updated by the main potentiometer.
I just have to wait for those new 20pF capacitors now... :roll:
Fender3D
Post by Fender3D »
MXR used to ... use sockets for BBDs.
I would take the SAD off and check if the clock works without it.
BTW
don't struggle for those tiny caps... they hardly fail,
Noth
Post by Noth »
I guess I had some ground trouble, the black wire was almost cut.
After fixing that, I now have a proper "almost-quare" clock but the frequency seems to be too high: 72 KHz
I did test with and without the SAD chip, that doesn't seem to have an impact.
I will still investigate on that part of the circuit, hoping the SAD chip is still alive anyway :)
Fender3D
Post by Fender3D »
72KHz seems in the ballpark...(remember it's halved inside the SAD) I don't know what's stock clock working freq, actually
Noth
Post by Noth »
Allright so..
Everything seems fine but I do have no signal on the SAD output., I guess I should join the "Dead SAD's club" .. :cry:
Thanks again for your help !
GorillaHuman
Post by GorillaHuman »
kdude34567 wrote: 31 Mar 2016, 14:38 Are these Hong Kong SAD512D bogus? Or are there things in the circuit that could be the problem?
Also replying to an older thread, but I'd just like to confirm kdude's story. I have the exact same problem; dead SAD512 and ordered a "hong-kong" one. Very faintly the BBD's output is audible, but lost straight after the first transistor. They are NOT up to old specs.
Pretty sure if I'd somehow amplify the output, it would become too noisy to utilize in practice.
GorillaHuman
Suspicion confirmed! I sourced a couple of vintage SAD512 chips and yes, the pedal works again as it should! The "Hong-Kong" SAD512d is definitely a bogus chip.
wannesg
Post by wannesg »
GorillaHuman wrote: 11 Jul 2020, 14:53 Suspicion confirmed! I sourced a couple of vintage SAD512 chips and yes, the pedal works again as it should! The "Hong-Kong" SAD512d is definitely a bogus chip.
Where did you find those? I'm trying to find two, for my micro chorus and micro flanger.
GorillaHuman
Sourced quite a few locally which I bought all. I send you a PM...
phillpark
Post by phillpark »
Let me revive this thread again. I read the whole topic and I'm not shure if akudedde or bucksears made the Fender3D PCB successfully.
ppluis0
Has thanked: 121 times
Been thanked: 278 times
Post by ppluis0 »
Hi folks,
Can be R16 and R17 replaced by an 500KB potentiometer to have a (sort of) dry/wet mix control ?
http://www.wizardinside.it/foto/schemi/ ... _schem.pdf
Fender3D
Post by Fender3D »
.....actually not....
because gain for both wet and dry signals is R15/R16 for dry signal and R15/R17 for wet, when pot is at its extremes you get very huge gain factor... resulting in huge volume jumps and great distortion
Search Geofex, there's a pan control you might better use...
Coldjoiner
Post by Coldjoiner »
Hi everyone,
maybe this will be a very helpful solution.
https://www.tfrelectronics.com/MicroChorus/
