As promised my version of the KORG CX3 1980's portable organ Rotary Effect.
This is definately not a project for beginners ( not another fuzz face or thuper hard on
I have kept it as close to the original KORG circuit as possible, with the following changes - an additional n channel jfet buffer at the input, a simpler fast/slow speed switching arrangement, and add on daughter boards to accomodate TDA1022 BBD chiips for those (including myself) who can no longer find the Panasonic MN3004 chips as originally used in the Korg.
The circuit also requires a 16V AC power pack ( it has it's own rectifier diodes and regulator chip on board)
I housed mine in a NSC 1790 case and bolted the 7812 regulator directly to it as a heatsink - works fine.
I used two TPDT footswitches - one for bypass - one for fast/slowspeed.
The slow speed is enabled by applying a small positive voltage to the marked pin on the board ( I used a 1K5 resistor in series with my three indicator leds and switched the earths accordingly - I took the the junction of the leds and the 1K5 for my small voltage source - +1.6v)
I was surprised when my build worked almost perfectly the first time I fired it up
There are 5 preset pots on the board - the first two reading from the top down, set the bias voltage to +6v on the two BBD chips - pin 3 for the MN3004, or pin 5 for the TDA1022
The bottom two presets ( left and right bottom corners) set the frequency of the bass and treble oscillators maximum speeds - KORG reccommend using a frequency counter and setting the bass preset (left bottom) to 145msecs and the treble preset to 130msecs. I used my ears to determine the most realistic beating effect.
The last preset in the middle of the board towards the bottom, sets the amplitude modulation (tremelo) gain - again adjust by ear to get the most realistic effect.
Well - there you have it - good luck, if you would like to build it, but you sure aren't gonna make any quick dosh building and selling these - you could build 50 SHO pedals for what the parts will cost you
BUT - if you build it - you will love it, and that's for sure
Okay - lots of room for mods - split the BBD delay lines , alter the balance between treble and bass sections, variable speed oscillators, stereo outputs etc. etc. If you feel up to it, you are most welcome to experiment. I built it to evaluate it - i have many thoughts in my head as to where to go next - PT2399 digital chips, true sine wave ( it has triangle wave oscillators) oscillators etc., so do not be surprised if you see a completely different unit this time next year
Enough rambling - here is the PCB and layout pics - PM me if you require higher resolution pics
baja mana mana
