It's not boxed up yet, but I finished the circuit for my own Baja CX-3 Leslie simulator and I have to say i love it. It sounds really smooth and with some mods the eq is very natural and complimentary to the guitar. I used MN3007 chips I got on Ebay from hongkongsuperseller. I was never able to get my hands on a 16V AC adapter, so I'm running a 12 DC wall wart to the DC output points on the rectifier and It works fine. Here's what I did for mods:
-The frequency response mod mentioned by analog guru on page 3 of this thread.
-750pf for the clock timer caps (-a must with the 3007 chips).
-Changed the 100k resistor across the 4558 for a 68k because I like a little boost on the effect, but not as much as the 100k was giving.
-Changed the low frequency (rotor) mixing resistor (R97) from 47k to 22k to increase the rotor volume
-Changed the high frequency (horn) mixing resistor (R94) from 200k to 330k to decrease the horn volume
(These last three resistor mods can be done with trimpots or even external pots to fine tune the balance of the dry, rotor, and horn elements)
-Changed the 3.3k resistor in the HF ramp up/down section (R47) to a 47k (like Andre said, I think the schematic calls for a 33k, but you can adjust to taste.)
-I've thought about changing the resistors around the frequency adjust trimpots (R103 and R106) and making them into external controls to have a wider high speed control on the outside of the box. I'll keep you posted.
-I think Bajaman mentioned which resistors control the slow speed too, so they could also be put on pots.
-Build to specs, the high frequency modulation (the horn) is a bit wide so I did what Andre suggested and a low pass filter at pin 9 of the 4046 (the right side of the component side of the board). This helped a lot and I was able to dial in a more subtle effect.
Still, it is useful to have the wide modulation too - you can get some great wobbly organ sounds. (by the way for you baseball fans, the classic dum dum dum dum - dum dum dum dum dudududududu Charge! is hilarious) Anyway, here are some sound clips
http://www.soundclick.com/bands/default ... tent=music The first one is with the horn modulation depth backed off a bit, and second two are full on. The last one has the depth up almost all the way. I think this setting is my favorite.
If you are looking for a rewarding but time consuming project I would recommend this one. Thanks to Bajaman for putting this whole thing together and making it available to the stompbox community.
