I just opened up both boxes and had a look, and yep, same pcb in both, but different components all over, different opamp/IC's and caps, etc.
I did a side by side with the two again to make sure I wasn't crazy, and I have to say again, they still sound very different. The root distortion type is still there, btu they are voiced *very* differently.
At the following settings, I get these results:
Volume at noon, bass, treble, and fuzz at max
Grunge box: HEAVY scooped mids, and more amplitude. Thicker, more rounded out bottom end.
Flashback Fuzz: Less amplitude, flatter EQ response, and somehow, slightly brittle sounding, even through a baritone, but run the volume at max and it gets much thicker pretty quick.
If I could have the higher gain and output of the Grunge with less of the scooped mids, more voiced like the Flashback, but with the Grunge's balls, that would be a really good circuit, maybe even a rival to the Rat2.
Here's a shot of both side by side:
And for contrast, here's the Classic Fuzz, which seems much more reasonable a circuit..I've had a burning question forever now: What the HELL did DOD need to make these circuits so fucking complicated for?!?!
And just for shits and giggles since I'm taking shots of the cheap-0's, here's the BOSS Hyper Fuzz:
