Cool !
Gotta breadboard this ...
culturejam wrote:Greg_G suggested some diodes to ground at the output might sound cool, so that's worth a shot if you plan to build this one.
May i suggest one or a couple of
series diodes or LEDs to ground (cathodes facing ground),
before the output cap ?
I did a quick simulation and i think that it might sound interesting, cutting the top of the square wave to let some original signal through. Depending on threshold, one diode would give less than unity volume, two or more increase the fuzzz. You might even control the amount of spike reduction with a pot shunting some diodes.
Hmmm, i realize it'll be less confusing with a picture :
PS : As you obviously used Eagle for schematic capture, why not using it for PCB layout too ? It's easier with consistency check !
