For quite some time now, we are flooded with spam. This time it seems to be generated by old accounts, probably using common and/or compromised credentials to login on FSB.
We'll go through the security checklist and, at some time, we'll probably need to force reactivation for the spamming accounts, at the very least. So, please, if you're using a username to login, note down the e-mail address associated with your FSB account, because it will be needed.
The G
digitally controlling pots with arduino
- theblackman
being a programmer i've been looking for something like this for a long time
- HydrozeenElectronics
Wow that was pretty cool, I wonder what one of them costs?
- RnFR
pretty cool. but he should've used the tone control! probably would've yielded far more interesting results.
is this what is being used in the WMD Geiger Counter?
- theblackman
yeah i didnt like the sound of what he did but i saw the potential. you could pretty easily make an ooh wah/zvex/vanishing point style controller with this. it also can read from a variety of sensors. so if you know a bit of computer programming the sky's the limit.
I wonder if it's fast enough to do something like an EH POG/HOG??
I know there are a lot of microcontroller projects like this, but this seems to be the most accessible for hobbyists like me!
@RnFR : not sure what a WMD geiger counter is..
@HydrozeenElectronics : they cost around $20.00AU which is probably around $17US. cheap as chips
That's a sweet deal, thankstheblackman wrote:yeah i didnt like the sound of what he did but i saw the potential. you could pretty easily make an ooh wah/zvex/vanishing point style controller with this. it also can read from a variety of sensors. so if you know a bit of computer programming the sky's the limit.
- lolbou
But you need a special software to get these programed? And some assembly langage skills?theblackman wrote:they cost around $20.00AU which is probably around $17US. cheap as chips
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
In Italy is costs 26€ http://www.robot-italy.com/product_info ... cts_id=878.lolbou wrote:But you need a special software to get these programed? And some assembly langage skills?theblackman wrote:they cost around $20.00AU which is probably around $17US. cheap as chips
The programming language is Processing/Wiring, that is a simplyfied JAVA specialized in electronic art, interactive design, electronic installations and stuff like that.
That is a LOT easier than programming a microcontroller in its own assembly language.
http://en.wikipedia.org/wiki/Processing ... anguage%29
http://www.wiring.org.co/
It's a cool thing, but it doesn't really interests me to the point to try it. I think that is great if you plan to do some performative gimmick such as ambiental sensors controlled audio processing, but I'm not much into that stuff.
- theblackman
nah it's a c based library, i think you can program it in java as well. the arduino is primary designed to be easy to use for artists and hobbyists. i found beavis on beavis audio made a simple step sequencer for it that could be easily moddable to do the same as a lot of guitar pedals that have sequncers in them.
- beavis
Arduino sequencers are a load of fun. As for programming, the language is simple and approachable, nothing like C or assembler.
I built a simple synth/sequencer based on the arduino with just a few parts:
check out at: http://www.beavisaudio.com/projects/dig ... unkConsole
Here's a long article on a project I created to use an Arduino to active as a programmable filter, this one uses an LDR to a filter:
http://www.beavisaudio.com/projects/DSWF/
Maybe that will help some?
beavisaudio.com
- JiM
Proco Rat
Hot Harmonics
Crackle Not OK
- Has thanked: 67 times
- Been thanked: 65 times
- Contact:
Yeah !
Arduino is coooool, cheap, and easy !
The language is in fact straight C, with a bunch of convenient librairies for controlling inputs/outputs for a lot of different things. You don't have to mess with complicated things like pointers, interrupts, or memory management (but if you want, you still can).
That's the great thing with such platforms : it's Free Hardware. Like Free Software. Like FreeStompBoxes.
No goop, open source, schematics provided. You can copy it as long as you acknoledge the original authors.
The official website with board info, free development tools (eventually based on GCC compiler), wiki ... http://www.arduino.cc
Some alternative boards : http://www.freeduino.org, http://www.sanguino.cc
I got mine from there (i like the compact size) : http://www.moderndevice.com/RBBB_revB.shtml
More related stuff : http://www.sparkfun.com, http://www.seeedstudio.com/depot/, http://www.adafruit.com
You can even do without a board ! http://www.uchobby.com/index.php/2007/0 ... readboard/
http://www.arduino.cc/en/Main/StandaloneAssembly
PS : i've also breadboarded Beavis' DSWF, it's FUN !
- theblackman
awesome thanks!
- Emanuele
This would be ace to make a sequenced filter with a real inductor..beavis wrote:Arduino sequencers are a load of fun. As for programming, the language is simple and approachable, nothing like C or assembler.
- Jack Deville
arduino is neat. a friend and i finished up a project for a pinebox car on tuesday.
the arduido monitors outputs from a LIS302DL (i believe that's the part he used) and transmits data wirelessly to a computer, which then updates facebook and twitter with the status of the car (ie: car going uphill, car going fast, car going slow, car is upside-down etc.). we added a few "ground effects" leds that respond to the cars position using arduinos easy to use PWM.
only downside to arduino is cost and speed. the controller is fast, but i haven't found alot of documentation regarding execution speed and methods that the compiler/DE employs when writing to the controller. i assume its efficient, as it is a nice platform, but i don't like to make assumptions. that nearly always leads to problems. the language and syntax is very user friendly though. VERY user friendly. that's a major plus to the system.
as far as digital pots go, there are many choices and ways to implement them into stompboxes/other electronics. they're cheaper than "normal" pots, but they take up board real estate, and require some form of control (more real estate, power and design). i hate to be so negative. for my last application, i found a more efficient solution.
