Yamaha - NE-1 Parametric Equalizer [schematic]
- Silent Fly
Here some detailed gut shot with component values.
- Silent Fly
I hopeless in tracing circuits. Please feel free to start without me.lolbou wrote:That's cool silentfly!
Did you start reversing it? Or shall we go for it?
The switch in the Q control board should be this.
The output is grey (signal) and white (gnd) wire.
I don't know the value of C11 but if we can't guess it looking at the schematics I will measure it.
- Dirk_Hendrik
lolbou wrote:Cheers,
Any clue about the diode below the IC?
Runs from pin 8 to 4. Suggests reverse power supply protection. Therefore it's value is of limited importance for tracing the circuit.
- Silent Fly
I agree - something like a 1N400x should be ok.Dirk_Hendrik wrote:lolbou wrote:Cheers,
- lolbou
Version 0.0...
Hope there ain't no big mistakes in it... ANd if someone has a better way to draw the Q-switch (to make if easier to understand) let me know!
BTW, I think the two pots were mislabelled (freq and level)... But what about values?
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
- Silent Fly
Apologies. You are right lolbou. The labels are wrong.
The values are correct. The double pot is A50K (freq) and the other one is A20K (level)
- SPeter
- lietuvis
The 47K resistor goes to ground,LED goes from positive via 10K,and switch is wrong.
In SHALLOW position should be C7 shunted by C5,R4 shunted by C6 and R7 in serries.
In DEEP position like there is no C5 and R7
In NORMAL position C7 is shorted and R4 shunted by C6.
hope this would help.
- lolbou
A LFO+LED/LDR could be added in to be used in place of the frequency pot to give a sort of auto wah...?
I had a hard time thinking on both sides of the PCB too... Where's left from rightSilent Fly wrote:Apologies. You are right lolbou. The labels are wrong.
- DimebuGG
I'm a little confused in the configuration of the rotary switch. Anybody?
BTW, lietuvis's tracing is correct.
- george giblet
Pretty much identical to the Robin Tomtlund's trace of the "Fender JB Special preamp"!!! (probably 9 years old now)
http://hem.passagen.se/robin2/effects.htm
- lolbou
lietuvis wrote:The 47K resistor goes to ground,LED goes from positive via 10K,and switch is wrong.
Back on it for next version...DimebuGG wrote:BTW, lietuvis's tracing is correct.
Lieutevis made a better job on drawing it though!DimebuGG wrote:I'm a little confused in the configuration of the rotary switch. Anybody?
- RnFR
i'm not quite sure why pot 1 is a dual. anyone have any idea?
- lolbou
Version 1.0:
Any better?
Any better?
Some second order filter (two RC networks)for better selectivity in frequencies?RnFR wrote:i'm not quite sure why pot 1 is a dual. anyone have any idea?
- analogguru
A similar filter configuration canbe found in the Ibanez ST-9, the Ibanez STL and the Pearl OD-5. All from the (early) 80´s.
