Schem updated to version 1.1.
ps: can anyone delete the older versions? Or leave them for awhile waiting for further corrections/improvements?
george giblet wrote:> Schem updated to version 1.1.
You mean the B+ on my schem? To me it's already like that on my drawing...Dirk_Hendrik wrote:The 470k resistors do not go to the battery supply but to a half vcc bias supply made by R5, R6 and C4.
a DPDT with center off toggle switch will do...tube-exorcist wrote:You can use a more common 3-position 2-pole toggle switch instead of the rotary switch.
lolbou wrote:You mean the B+ on my schem? To me it's already like that on my drawing...Dirk_Hendrik wrote:The 470k resistors do not go to the battery supply but to a half vcc bias supply made by R5, R6 and C4.What am I missing?
It is C5. I wrote "B22K". I just realised it should be "822K".Dirk_Hendrik wrote:I guess i'm blind but where does that 8n2 value come from?
Yes, I translated it... I thought that a two-legged green 22k linear pot was too weird...Silent Fly wrote:It is C5. I wrote "B22K". I just realised it should be "822K".
The "8" looked very much like a "B".
The B+ on my schem comes from the 39k/47k network (R5/R6 divider for biasing)... You mean I should have called it 1/2Vcc (even if it's not exactly 1/2) instead of B+?Dirk_Hendrik wrote:The 470k resistors do not go to the battery supply but to a half vcc bias supply made by R5, R6 and C4.
