Page 2 of 3
Re: Yamaha NE-1
Posted: 26 Aug 2009, 07:43
by lolbou
Looking at the units you pointed out AG, I realized that they have NP caps before the tone stack... :hmmm: Which was what Silentfly note down on his pics! :wink:
Schem updated to version 1.1.
NE-1 - schematic 1.1.pdf
(90.73 KiB) Downloaded 481 times
ps: can anyone delete the older versions? Or leave them for awhile waiting for further corrections/improvements?
Re: Yamaha NE-1
Posted: 26 Aug 2009, 08:56
by george giblet
Something went wrong with the first switch on that version.
The circuit is a just a variable frequency notch filter. The switching at the front end makes the first stage gain unity in bypass mode and tweaks the gain to be above units when the notch is in place - the idea here is the notch sucks out some signal and the small increase in first stage gain tries to compensate for this so the perceived level is the same. (The gain compensation is used in quite a few bass amp "voicing" circuits which often incorporate fixed notch circuits.)
Re: Yamaha NE-1
Posted: 26 Aug 2009, 09:16
by lolbou
george giblet wrote:> Schem updated to version 1.1.
:slap: :slap: :slap: :slap: :slap: Sorry about that... :oops:
Right George, the NP cap should link the common pole of the first switch...
Corrected...
Version 1.2
NE-1 - schematic 1.2.pdf
(90.86 KiB) Downloaded 489 times
Re: Yamaha NE-1
Posted: 26 Aug 2009, 10:34
by Dirk_Hendrik
The 470k resistors do not go to the battery supply but to a half vcc bias supply made by R5, R6 and C4.
Re: Yamaha NE-1
Posted: 26 Aug 2009, 11:07
by lolbou
Dirk_Hendrik wrote:The 470k resistors do not go to the battery supply but to a half vcc bias supply made by R5, R6 and C4.
You mean the B+ on my schem? To me it's already like that on my drawing... :scratch: What am I missing?
Re: Yamaha NE-1  [schematic]
Posted: 26 Aug 2009, 12:17
by DimebuGG
Re: Yamaha NE-1
Posted: 26 Aug 2009, 13:46
by estragon
Cool!
Only thing that looks strange is that in the FLAT position you need to dime tha LEVEL pot so as to have unity gain.
Re: Yamaha NE-1
Posted: 26 Aug 2009, 14:16
by Silent Fly
Thanks everybody for tracing the circuit.
It is a nice little box. It is a little bit boomy (especially in the "deep" setting) but apart from that it is worth build it.
Re: Yamaha NE-1
Posted: 26 Aug 2009, 14:23
by tube-exorcist
You can use a more common 3-position 2-pole toggle switch instead of the rotary switch.
Re: Yamaha NE-1
Posted: 26 Aug 2009, 15:14
by DimebuGG
tube-exorcist wrote:You can use a more common 3-position 2-pole toggle switch instead of the rotary switch.
a DPDT with center off toggle switch will do... :wink:
Re: Yamaha NE-1
Posted: 26 Aug 2009, 17:05
by Dirk_Hendrik
I guess i'm blind but where does that 8n2 value come from?
Re: Yamaha NE-1
Posted: 26 Aug 2009, 17:06
by Dirk_Hendrik
B+ is vcc, the battery voltage. Those 2 470k resistors are not connected to b+. I think you swapped the 2 red wires on the photo's ;)
Re: Yamaha NE-1
Posted: 26 Aug 2009, 17:51
by Silent Fly
Dirk_Hendrik wrote:I guess i'm blind but where does that 8n2 value come from?
It is C5. I wrote "B22K". I just realised it should be "822K".
The "8" looked very much like a "B". [smilie=sorry.gif]
Re: Yamaha NE-1
Posted: 26 Aug 2009, 18:19
by lolbou
Silent Fly wrote:It is C5. I wrote "B22K". I just realised it should be "822K".
Yes, I translated it... I thought that a two-legged green 22k linear pot was too weird... :lol:
The B+ on my schem comes from the 39k/47k network (R5/R6 divider for biasing)... You mean I should have called it 1/2Vcc (even if it's not exactly 1/2) instead of B+? :scratch:
To get rid of my colorblindness, I used the Wx wire names... :wink:
Re: Yamaha NE-1
Posted: 26 Aug 2009, 18:20
by Dirk_Hendrik
:roll: Me stupid too Image
Re: Yamaha NE-1
Posted: 27 Aug 2009, 14:58
by Silent Fly
I hope it is of some interest - it looks like bassists are a tiny minority here. [smilie=a_damnit.gif]
I modded the NE-1 I recently purchased second-hand. At least with my basses the DEEP setting was far too extreme. Now I can get much more musical and useful sounds.
C6: removing C6 makes the 3 "Q" settings at the same volume. It is much more practical than constantly moving the volume knob to compensate volume variations.
Depth control/filter type: I added a double pole 3 position switch (on-off-on). In position 1, the NE-1 operates normally. In positions 2, C5 and C7 are removed from the circuit; the NE-1 operates as a variable LP filter. In position 3, the NE-1 has two new more subtle (and usable) sounds for shallow and deep.
Some of original settings of the NE-1 are not too bad but with a modded version I can get all the type of sounds I like from slap-machine sounds, to more fingerstyle sound (Jaco-like), to ultra-deep.
Re: Yamaha NE-1
Posted: 27 Aug 2009, 15:01
by Silent Fly
If you plan to build a NE-1, you may find this version interesting.
The Q control varies continuously and a switch changes the filter to low-pass.
Yamaha NE-1 (Silent Fly remix)
Re: Yamaha NE-1
Posted: 28 Aug 2009, 00:48
by OldMan
Hello all
Im OldMan a new Bassman here, my first post, I'm from Switzerland,
I can't see the sense of R12 can enyone explain please?
OM
Re: Yamaha NE-1
Posted: 28 Aug 2009, 04:03
by george giblet
Prevents opamp oscillation with capacitive loads. (Also has benefits for shorts, ESD, RF.)
Re: Yamaha NE-1
Posted: 29 Aug 2009, 01:00
by OldMan
Thanks vor explaining
Perfboard anyone?
