Grounding issue on painted boxes
Frequent question about boxes and accessories: painting, etching, clearcoating, lettering, glueing, and so on.
mojoh
Post by mojoh »
also...i have a question re Grounding to the enclosure...especially if painting the exterior of the enclosure...
do you have to file back the paint from the input/output jack holes?
Naz Nomad
Post by Naz Nomad »
The jacks will ground well enough on the inside of the enclosure, so just remove paint from there if you managed to somehow get loads of paint inside ... any paint in the actual hole and under the washer/nut should be no problem at all.
