Curried Stompbox?
Since you seemed to like the last book, I have two other out of print books I have come across getting around the internet. Ifound both of these on the "freebookspot" website, the first an Indian one is at http://rapidshare.com/files/158909807/E ... ._Sood.rar and the second is the better known Anderton book, which is at http://rapidshare.com/files/85181520/C5 ... 3899C1.rar and they may require a password to extract the rar archive (a more efficient form of file compression - you can open these with the free utility "7 Zip".
wouldn't that sound better with a harpsichord and a phaser on it?
Can so be opened with 7zip! "the password is actually (sorry forgot and abbreviated it without thinking) "www.freebookspot.com". I'm sure it was really a good idea to make their web address their password! 7zip will freeze if you don't use the ocon to extract but try to do it via drag and drop.
- borislavgajic
- Opamp Operator
- Has thanked: 131 times
- Been thanked: 277 times
I have this problem....what is project20 (page 34)...it says ...A single tansistor phaser.....
when I read ,I see those printing errors.......often.....
thanks for great book
boris
boris
Are you serious?borislavgajic wrote:I have this problem....what is project20 (page 34)...it says ...A single tansistor phaser.....
boris
- borislavgajic
- Opamp Operator
yesNaz Nomad wrote:Are you serious?borislavgajic wrote:I have this problem....what is project20 (page 34)...it says ...A single tansistor phaser.....
boris
- RnFR
it's not what you would normally consider a phaser, but a way to adjust phase.
- JiM
Proco Rat
Hot Harmonics
Crackle Not OK
- Has thanked: 69 times
- Been thanked: 65 times
- Contact:
I was surprised too, but in fact it's a "single-transistor phaser-stage". Without LFO too.
It's a kind of simplified Univibe phase stage. http://www.geofex.com/Article_Folders/u ... frindx.htm
You need at least two of these (and mix it with the dry signal) to create notch(es) in the frequency response.
I just put stuff up that I find you know, so I don't really know for sure. I think the guy is just kind of putting forward an idea. I think myself its realy what you'd call a notch filter kind of, which would give the sort of a sound of a phaser without the movement associated. It's a long time since I really experimented with electronics but you have to wonder of you could use it say to creat an effect that involved a few of these chained like a chaser disco light, and perhaps make it either sensitive so that it adjust to the beat of the music or could be hand adjusted. On the other hand I suppose you could try something entirely new and wire them in with other effects so you get say blast of fuzz, blast of phase, blast of fuzz etc...
