Aria - DT-10 Dual Distortion
I still use this pedal and its sound has held up, even though it's not the sturdiest design. I like that one can pre-set a higher gain level for solos. I recall reading somewhere that the Aria DT-10 had a bit of cache because it used the same chip that is found in the Ibanez and Maxon distortion pedals from the 80's. Anyone here have more insight?
- analogguru
Yes, those are inside too, but only for switching.JohnSS wrote:Nope. Mine has 2 chips: a TC4013BP/8419H and a TC4069UBP/8506HB. Is there anything that you can fill me in about this pedal?
There is another 8-pin chip inside, a 4558D (and six FET´s 2SK30A-Y).
The audio-path consists of:
A Fet-buffer,
A Fet-amplifier stage,
A MXR Distortion+ opamp stage with diode clipper,
followed by an EH Big-Muff-Pi type tone-stack,
volume poti,
Fet-switching,
opamp output buffer.
Since this is a MXR Distortion+ style - as the name says - "Distortion" (and not Overdrive) it is not really important which 4558 exactly is inside.
Mine does have the JRC4558D Chip and believe you me, this thing sounds really rancid!!!
- modman
- a d m i n
- Has thanked: 4287 times
- Been thanked: 2008 times
Junkie4Analog wrote:Mine does have the JRC4558D Chip and believe you me, this thing sounds really rancid!!!
analogguru wrote:Yes, those are inside too, but only for switching.JohnSS wrote:Nope. Mine has 2 chips: a TC4013BP/8419H and a TC4069UBP/8506HB. Is there anything that you can fill me in about this pedal?
