BAJA Small Clone
The only part I cant obtain is a 2n7 capacitor!! Could I sub a 2n2?
You could try adding a 470p in parallel with the 2n2 capacitor :wink:
rocklander
Has thanked: 1404 times
Been thanked: 227 times
Post by rocklander »
thanks again for this project Steve.. it continues to be my most and least favourite build at the same time.. finished populating a board tonight for our bassist and it was very quiet, and just had a slight oscillation sound, but not the chorus effect.. 3 of the tightest tracks had shorted, but were invisible to the naked eye.. she's a TIGHT build/intricate pcb.. but an absolute bundle of joy! 8)
rvargas
Post by rvargas »
Hi guys, A friend asked me to build one for him and I based my PCB on tonepad's (redid it since I like to have the 3PDT built into the board for support).
It works fine but I have some questions:
Pedal sounds dark compared to no pedal at all, both on bypass and on effect. Could it be extra capacitance from the traces to the jacks? IS there a way to set it a bit "brighter"?
There is a little noise going on, especially if I start twisting the depth pot to the top, it starts a high pitched oscillation.. if I turn it all the way through it stops sounding. I tried this with different trim pot settings and there is always a point were it doesnt sound good anymore.
Question about the volume -> I saw in another post, substitute 10K resistor near the 4558b for added gain
I attach an image of my layout for reference. It follows more or less the one at Tonepad, a little arrangement to fir the board. Thanks for all your help, I love this forum!
Small Clone PCB
Small Clone PCB
chile
Has thanked: 16 times
Post by chile »
hi all,
built ne with this layout, works fine!
A/B with an EH and mine have less hi freq... it lacks those shimmering highs tha the EH as.... tried t sub the opamp but no improvemets... some suggestion?
chile
Post by chile »
seems the key is the 6.8k>10n in the feedback loop of the last stage...
correct me if i'm wrong: it is configured to tame a little bit the highs boost on the first stage... maybe because the n3007 section darkens the sound they boost at 2000-3000 before and cut after?
i'm spicing a bit to find the right conf...
Greenmachine
my favorite amplifier: Fender Blackface Deluxe Reverb
Completed builds: Electra Distortion
Roger Mayer Octavia
Klon Centaur (Bajaman/Soulsonic)
DOD 440 Envelope Filter
MXR Phase 90
DOD FET Preamp
Dallas Arbiter Fuzz Face
Soulsonic Hunny Bunny Overdrive
BYOC Analog Delay
Craig Anderton Headphone Amp
Anderton Mini Amp
Bajaman Real Tube Overdrive
Fender Deluxe 5E3 with Tone Stack Mod.
Fender Princeton 5F2-a
Keen Neovibe
Aquapuss Delay
Anderton AMS-100 Guitar Synth (abandoned)
DOD 280 Compressor
Weird Sound Generator
Beavis Audio Noisy Cricket
80's Rat
ROG Thor
Big Muff
Green Ringer
Shin-Ei Fuzz
MXR Dynacomp
COT50
Really Cheap Compressor
Has thanked: 87 times
Been thanked: 15 times
Post by Greenmachine »
Bajaman (or anyone ...) what would happen if I stuck a MN3008 in here instead? (Twice the # of BBD's) Something cool? Likely something not.
Just curious.
Greenmachine
Roger Mayer Octavia
MXR Phase 90
DOD FET Preamp
BYOC Analog Delay
Anderton Mini Amp
Keen Neovibe
Aquapuss Delay
DOD 280 Compressor
80's Rat
ROG Thor
Big Muff
Green Ringer
Shin-Ei Fuzz
MXR Dynacomp
COT50
Greenmachine wrote:Bajaman (or anyone ...) what would happen if I stuck a MN3008 in here instead? (Twice the # of BBD's) Something cool? Likely something not.
Just curious.
Never mind, Mark Hammer answers this question on Ampage.
Tyand
Post by Tyand »
hello all. I ve tried the small clone with my active bass and i was amazed by the sound. But playing hard notes, leads to distortion. Sure i can turn down the volume on my bass, but i would like to increase the headroom of the small clone to 18v.(i have a 18v supply on my board) How can i mod it ? Is this possible ?
Thanks for help tyand
G5120fx
Has thanked: 37 times
Been thanked: 29 times
Post by G5120fx »
I just build it and it doesn´t matter how i turn the trimpot, I get no chorus.
I bought the mn3007 chip from a ebay seller "leemoom611". Has anybody ordered mn3007´s from them and can confirm they are fine?
Here are some voltages of the IC´s.
Is it normal that Pin1, 5 and 7 have voltages that goes from very low to higher?
I´m gonna check the pcb under the microscope tomorrow.
I have a normal guitar signal when i turn the the effect on....
I made some pix, maybe you can see a mistake?! I desoldered the trannies and socketed them, I also desoldered the trimpot and soldered it to a lil piece of vero (I wasen´t sure if the trimpot was ok)
G5120fx
Post by G5120fx »
I can´t edit my post, but here are the voltages of the trannies:
Q1 (next to lm358): CW --> C:0, B:0, E:0 CCW --> C:0, B: 8,53 E: 0
Q2 (next to cd4047) C: 8,17, B: 8,64, E: 8,72
Q3 C: 8,72, B: 4,92 E: 4,77
Hope this helps!
G5120fx
Post by G5120fx »
anybody? :?
rasta_maleek
Has thanked: 52 times
Been thanked: 52 times
Post by rasta_maleek »
G5120fx wrote:anybody? :?
You got the 1n4148 in the wrong side. Maybe you could use to guide the tone pad's small clone.
Cheers.
A photos of my last one.
I built a couple but in the moment that someone ear it, ask me for sell it.
Controls
Depth, rate and mix, switch-1, 150p/330p. Switch-2, 1uF/2,2uF.
Watch at the diode next to the cd4047
Mods, pulse led, mix and switches
G5120fx
Post by G5120fx »
Thanks Rasta, you are right. I found the mistake shortly after I posted my last reply. It were the Diodes.....
It´s working fine now
edd101
Post by edd101 »
Cheers.
Controls
yo,
please tell, how did you wire a MIX pot.
Ed
rasta_maleek
All about mods in this proyect is aviable in tonepad´s poyects small clone and CE 2.You must change the resistor coming from the BBds section to a pot wired like a variable resistor. Take a look over the tonepad proyect reports in the download page of the proyect.
plesur
Has thanked: 18 times
Been thanked: 80 times
Post by plesur »
I've been doing a bit of work on the Small Clone and compared the Tonepad schematic to an EHX schematic I found here: http://sites.google.com/site/electrocon ... ctoryE.pdf
There's a couple of differences:
The 10n cap that joins to pin 2 of the 4558 through the the 6k8 resistor has other end to ground in EHX schematic and 4.5V in the Tonepad
The 47n cap goes to ground from pin 3 of the LM358 in the EHX but from the rate pot in the Tonepad
Can anyone with a original unit help me confirm which is right? :?:
foo zen trader
Been thanked: 9 times
Post by foo zen trader »
plesur wrote:I've been doing a bit of work on the Small Clone and compared the Tonepad schematic to an EHX schematic I found here: http://sites.google.com/site/electrocon ... ctoryE.pdf
Same question here... !?! Anyone out there who could help?
JABBA DABBA DOOM
2015 update:
I now have updated double sided boards from OSH PARK available for this project if required. Please PM me for details if interested in purchasing.
top silkscreen.png (137.98 KiB) Viewed 2128 times
....and some more pics of a recently built pedal using the OSH PARK boards - the black wire in the internal picture was added because I accidentally broke the trace from pin 1 of the LM358 to the depth pot. :slap:
mictester
Has thanked: 32 times
Been thanked: 825 times
Post by mictester »
The first difference won't matter - the "mid-rail" (the 4V5 line) is effectively grounded as far as audio is concerned because of the 10µF capacitor across the lower arm of the potential divider - that audio stage will work the same either way.
